#61
No, because the spring is where the centrifugal device is.
When you open the PV with the linkage engaged, it can happen that the steel ball go out and than you have to open the clutch housing and repair this. In my opinion there is a carb problem and no PV.
4 strokes are only good for power generators |
#62
Im talking about the springs up in the cylinder.
Im also into a carb problem but Ive tried 3! Different carbs now!? |
#63
My best jetting so far is 40 180 and n3eg in 2nd from top. Now its possible to ride it but not as good as it should be.
#64
Way too lean for a 125, there must be something else wrong.
#65
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#66
What was wrong with yours?
Would it be acceptable with 45? 48 didnt work at all. |
#67
2 thinks I'm thinking about:
Which pipe are you using, hope not the kat pipe The 125 had no CDI with 2 settings for rain and dy
#68
Not sure what pipe. I have a doma pipe also. Maybe i shall try that one?
It has no switch like my 300 does.. |
#69
Yes try it!
#70
after todays ride even my girlfriend thinks the bike runs bad in the mid range... and it's the 4th time ever she's riding a bike....
Since I've been doing everythink to the carburator I'm up to order new reed flaps and a piston. So what year Yz125 piston will fit my EC125 -01? I've searched but not found exactly what years that will work.. |
EC125 Power Valve and Oil | oldschool07 | Enduro Engine - 2 stroke | 11 | 09-27-2015 02:34 PM |
S3 cylinder/power valve help? | '11EC300 | Enduro Engine - 2 stroke | 7 | 06-02-2014 08:18 PM |
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
power valve nut | bonkeye | Enduro Engine - 2 stroke | 4 | 10-11-2012 06:40 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
