#61
Normally, no where near what you heated the cases to for the install. Nothing wrong with the polyamide cage, the NJ series open two piece roller uses one as well. It's the logic in choosing a sealed part that is flawed IMO.
While your in research mode, what material used for the seals? What is its compatibility with fuel components, especially ethanol? Sent from my iPad using Tapatalk HD |
#62
Heat the cases and drop the mains back in the same was as stock. No seals. I'll have to reseat one of the small bearings on the back side which half dropped out when I heated the cases last night removing the mains. I think I'll slide them both in the oven again on Monday and slip them in between servicing the car. In regards to the seals: RSL and RSH seals share many important properties including the elastomer material and reinforcement. Seals The RSL and RSH seals are made of acrylo-nitrile-butadiene rubber (NBR), which has an operating temperature range of -40 to +100C and up to +120 for brief periods. The seals provide good resistance to - most mineral oil based lubricants - fuels, including petrol, diesel and light heating oils - oils and greases based on animal and vegetable fat - water. From my researching of chemical resistance tables, it seems that Ethanol (Ethyl Alcohol) has little to no action on this compound. |
#63
I found "Fair to Good" for alcohols, and "Poor" for Esters, which are a base stock component for some high end two stroke oils like Motul and Redline. Bad decsion, period.
#64
Interestingly, I also read that the use of such EP Additives also have a negative impact on the life of polyamide bearing cages. Most noticable when combined with high temps. The wear would still be acceptable for our purposes though. We're talking when aiming for 1000's of hours of use.
#65
Nitrile is good for general fluids, but questionable when chemical additives are present. Viton is a much better choice. I prefer metal cages over plastic for this application.
2011 EC250E |
#66
Amazing how much simpler things go when you know what you're doing. Basically a 2 minute job this time around. Heated cases sufficiently. Bearings dropped right in. Made sure all were seated properly and left to cool.
Now off to service the car. If I get time later I might start dropping the transmission back into the case. In regards to fitting the crank, whats the best method? Is it worth while heating the inner race of the bearing using a socket and torch? Or just a frozen crank should drop right in? |
#67
This write up and photos is GREAT!!
I have learned a lot. I am sure you have already seen this, but for others that have not, here you go. Steps & Photos to rebuild 2-Stroke http://www.dirtrider.com/features/two-stroke-rebuild/
2012 - XC 300 Racing Seattle, WA |
#68
Frozen crank should do it. Actually sometimes it's just a tight slip fit, and a few taps with a plastic hammer does it. Like I said before it should be nothing like the case fits. Build everything into the primary side case, then seat the ignition side.
#69
just for the folks playing at home would it be possible for you to outline the best methods you ended up with for 1. getting bearings out of the case and 2. getting them back in?
#70
Installation was the same. Needle rollers needed help. I used a socket on the other race and careful worked it in (still on a hot case). The rest dropped right in as long as I took care to align it properly. Pushing it in by hand with a motorcycle glove was enough to seat them all fully. |
First Top-End Rebuild on a 2007 EC250 | speedy08 | Enduro Engine - 2 stroke | 9 | 06-22-2011 09:16 PM |
EC250 engine rebuild? | robszombie | Enduro Engine - 2 stroke | 3 | 12-07-2009 11:38 AM |
