#71
Solution
Spot on!
The black pipe has something at exactly the same spot as the KTM pipe in the pictures. Couldn't find anything good to poke with but put together a small bolt and jingled it around. After trying from both ends, the bolt klanks around but stops right at the weld by the fattest part and can in no way go past the obstruction. So, on with the new FMF Gnarly doma copy and a CCK needle on #3, and a 178MJ. Pipe had small crack right behind the flange where the two stamped halves meet. Cleaned both sides w contact cleaner and put on some quick-steel and let dry for 20mins. Some permatex on the pipe and it slid right in. Except for the small crack, fit and finish is perfect. E-line pipe guard for stock pipe did not fit at all. Started it up and noticed a different, raspier sound. Took it off choke and rode it under light load through the gears to clear the blubbering. Stopped to check the engine temp on the back of the cylinder on the intake side and it was warmer than usual. Now that it was warmed up and cleared out I took it for a spin. Sure the CCK is linear, but it runs like a RAPED APE! Couldn't stop laughing! Whooa! Finally some open-class power. From below idle, it runs clean, strong and completely linear to crazy high revs. Wheelies in fouth gear from pure roll on is no problem. And the sound! Howls like a factory MX bike. Will try to raise the needle and go up to a 180 just to check if it's a little too lean and see if the engine temps come down a bit. So cool! Thanks for all the input guys.
mint 2008 EC200. Earlier bikes: Husqvarna WR125 '12, Husaberg FE450 '10, Sherco 4.5i '05, EC300 '07, YZ450 '03, WR250F '01, WR400F '00. |
#72
Where did you find the CCK needle ?
Would like to try one myself. |
#73
RB Designs has them in stock!
#74
RB-Designs is a sponsor here on the website - Ron's website can be found at www.rb-designs.com
thx, jeff |
#75
So i have another question for all of you jetting guys out there. I have a 2002 EC250. Here were the settings befor my LTR jetting kit that i put in today.
#7 slide PJ #35 Stock needle clip position #2 MJ #175 Air screw 2 turns out At 2000-2500Ft. This set-up was fairly hard hitting middle and good top end with a decent bottom end pull. With the LTR kit installed the bike seemed very smooth. Most of my ridding is sand and open areas for now. What can i do to get more HIT out of the bike as far as jetting goes? THANKS!!!
2002 Gasgas EC250 (gone not forgotten) 2012 Ktm 300xc 2001 Gasgas EC300 Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!! |
#76
The LTR needle (single taper) takes out the hit. If you want the hit I'd look at running the N1EF (triple taper) needle. One of the guys posted a great write op on a handfull of neeedles. You should try to search it out.
2004 GasGas DE250 |
#77
Sure wish i would have known that befor i went and spent $56 on it.
Thats all right. If i end up doing some Hare scramble races this set-up could help me. I am going to try and lean every setting out one step and se what happens. Thanks again.
#78
I think the RB carb mod would be what you are looking for.
Ron |
#79
swapping out needles is easy on 2t's ...
throw the stocker back in there and see what you think. |
#80
throw the stocker back in there and see what you think. btw I think it was "pobit" who made the needle post. pull up his profile and search for his posts |
2010 ec 300 report | gg3 | Ride Reports | 18 | 05-16-2010 11:07 AM |
WEC report - Gas Gas | stay_upright | General Discussions & Announcements | 2 | 07-23-2008 07:00 PM |
wec race report | fury1 | Ride Reports | 4 | 08-21-2007 06:56 PM |
'07 ride report?? | GMP | Enduro Engine - 2 stroke | 11 | 07-06-2007 06:13 PM |
Rebuild Report | PEB | Enduro Engine - 2 stroke | 0 | 12-12-2006 12:44 PM |
