Old 07-24-2019, 04:33 AM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
Originally Posted by rodent View Post
Thanks for the reply Rudolf
Could you shoot me a PM with a link to yours? Would you send to OZ? Will you pull from auction to sell?
Yes, yes and yes. PM sent.
Old 07-24-2019, 04:46 AM
The sump guard is a 6mm AXP unit with link guard. Additional graphics are from the UK GasGas importer's accessory site via the link in my earlier post.
Enduro Engineering wraparound guards and rim decals from eBay in the UK.
The UK GasGas importer, John Shirt, is a really good guy, veteran expert rider and has been the importer since GasGas started in the UK. He has massive spares stocks going back to early models and ships worldwide every day.
Old 11-11-2019, 03:47 PM
Spanish Christini Spanish Christini is offline
Great thread--subscribed, as I've got a 2014 Christini with what appears to be a 2013 (at the newest) GASGAS 300 EC in it. Per the GG shop manuals, the bike should have a Keihin 38 on it, but I've only recently got the bike and haven't yet got good access to it where it's stored.
Did the carburetion change significantly from 2013 to 2019 on GG's 300 EC's?
Thanks.
Old 09-28-2021, 02:57 AM
Chugga Chugga is offline
Default EC300 2019 jetting
Hi all, been reading all the posts re, jetting for 2019 EC300. I?ve just picked up a low mileage 18hrs only EC300 and it?s running a bit rich. I live on the Gold Coast Australia and ride from 0-500 feet in temps of 13-30?c. Previous owner mentioned jetting is pretty standard, I think he changed the main but not the pilot or needle. Running Maxima Castor at 40-1, this was already in the bike and I had planned to use the same, I?m a bit old school!. I now many of you mention to change the needle and main, but so many posts I?m getting a bit lost. Any guidance on base settings would be much appreciated. Thanks
Originally Posted by Davehuge View Post
If you give us your location/altitude/temperature then Jakobi might be kind enough to suggest a starting point for jetting, to give you a head start.
The standard no.7 slide is usually OK, so it"s a matter of trying different needles, main jets, pilot jets and clip positions. Most important to just make one change at a time, then test and keep notes so you don't get lost.
Make sure you're using a good quality full synthetic oil mixed at 50:1 (usually 50:1 but please check).
If you speak to your dealer (where you've just spent thousands) I would hope they'd help you out with supplying jets/needles at a discounted price! I wish GasGas and other manufacturers supplied a selection of jets/needles with their bikes.
Congratulations on your new bike, it looks stunning, I'm very jealous!
Old 09-28-2021, 02:54 PM
I always used 40:1 but the reality is that you jet according to your mix.
so stick with one mix and adjust the jetting (I would also go a bit further and stick with one 2-stroke oil too)
2003 txt250 Pro
2013 Ossa 280i
Old 09-29-2021, 01:56 AM
ditezz ditezz is offline
Im in Sydney have a 2021 reiju ,which is same as yours I ride in same temps and elevations . NEDW needle on 2nd clip from top ,40 pilot ,air screw 1 1/2 turns out ,standard main .The needle is a triple taper as opposed to the double taper standard needle. Its from a Suzuki RM 250 . MX store on the Gold Coast will have it .Good luck
Old 09-29-2021, 01:58 AM
And try 50:1
2019 Gas Gas updates swazi_matt General Discussions & Announcements 150 10-29-2018 05:24 PM
2019 EC 300 first ride (euro model) Doc Brown Ride Reports 7 09-19-2018 01:17 PM
2019 gp CORSA General Discussions & Announcements 1 08-02-2018 06:37 AM
Poll 2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 16 06-28-2018 03:43 PM
2019 KTM XCW 300 TPI 6 Days Moto7man Pictures & Videos 2 06-21-2018 03:20 PM
