#981
I did 2 of my pipes recently. Do you have pictures of your setup? I wasn't real happy with mine but it worked. I just used a rubber plug in one end held on with safety wire. And the other was a a rubber pipe cap with a shrader valve and washers to keep it from distorting. 25psi. I used Mapp gas but I've got real torches just didn't want to heat too fast.
Matt 1999 GG EC 250 Six Days 1999 Cagiva Gran Canyon 2001 Aprilia Falco 2001 Triumph Speed Triple for my 20 year old 2000 GG XC250 for my 20 year old 2003 Honda Rancher 350 for the wife |
#982
Managed to seize the main bearings in the engine
#983
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#984
By the time the dents are all out, the pressure is way over 100 psi.
#985
These fellows have a pretty good looking set-up. My rosebud tip for my oxy-acetylene torch works faster than their propane torch. It's also better for those hard edged crease dents.
https://www.youtube.com/watch?v=Tp0Uuqo6LyE
#986
I went for my first ride since my surgery ! Over 4 months ! My wonderful wife insisted we go and that I drop out of the gym and ride my trials or enduro bike an hour every day I live for days like today on my Gasser Life really is great .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES |
#987
4 months!bet that was a sweet,sweet ride.reckon the gasser would have been more than in the mood for it too by then.was she snapping and growling at the shed door?
I fitted the TMD chain guide and slider.nice fit,quality product,makes the stock one look rather sad.got murdered on the exchange rate tho.the nz $ was worth .68us but what the hey!
2013 ec200r |
#988
hello, new to this forum. just purchased my first new (to me) GG 200. decided to send off the suspension and shock to LT racing after seeing all the good support this forum has given Les. anyway, i may have made this harder than i needed to so you are all allowed to giggle to yourselves. thanks for looking.
initial shot so i can remember the bike didnt look like a parts bike when i bought it taking the caliper off removing the forks from the clamps attempted to wiggle the shock out but couldnt get it to fit. looked like removing the battery case, airbox, and gas tank might do the ticket. nope. noticed a broken throttle cable when i was down there. well more like a broken metal part that maybe cracked off of the cap, cable looks fine. hopefully a cheap part? might ask the local shop about this before i attempt to put the bike back together. looked like removing the subframe would be the way to go. and it was thankfully. there we go, suspensionless. now the waiting game until i get the suspension back and for the snow to melt. |
#989
I believe it sorts out most dents and also tends to "untwist" pipes. I have a cf guard on my pipe so most of the damage is from bending at the neck - this should sort it out (but the pressure pump costs about $400!!)
#990
Ben you have the pwk as1 model carb and it looks like the brass cable reciever/tensioner has snapped.jetsrus may well have that part.was looking at slides on their site yesterday and you can find just about any keihin part no there.cross your fingers you dont have to buy the whole cap.while you have it in bits is a good time to take note of the slide no,the needle code and clip position(under carb cap),and jet sizes(inside carb bottom).dont change anything just establish a benchmark.that way if you want advice or suggestions from members on tuning later...
2013 ec200r |
DNF today | Pepperami | Enduro Chassis & Body | 6 | 09-18-2013 11:59 AM |
Got my first GG today! | RonMexico | General Discussions & Announcements | 6 | 02-19-2011 12:39 PM |
Went Riding Today and..... | coolum74 | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 11-30-2008 01:12 PM |
HELP! I tried to use my gasgas as a jet ski today! | sammyj18 | General Discussions & Announcements | 19 | 11-21-2008 08:01 PM |
SHNF From Today | Boomhauer | Pictures & Videos | 13 | 10-30-2007 04:18 PM |
