2006 ec 250
Hi guys I have a problem and I'm thinking it's electrical
Bike will start and drive perfectly and just randomly stops Try to start it an just splutters and dies So I just park it up Come back next day and it will start this has happened 3 times now same pattern drives great then stops then starts again a day later And ideas what this can be Bike has new plug Clean filter Bought the bike a few weeks back and the light were working they're not now Also there a few loose wire around the headlight and coil area Appreciate and input As i don't want to go replaced complete electrics Thanks in advance |
How far time wise do you go before it acts up?? I have had a bad coil and it would run perfect for about 10 to 20 minutes then start misfiring and or quit. Let it cool down and you were good to do again.
Unscrew the tank cap when it happens. There is a small chance you have a plugged cap vent. Carefully go over each wire and it's connections (clean them if needed). Broken wires around the headstock are common (your handlebars go back and forth a lot).
Check coil connections including the high tension lead. Check every ground, particularily where the coil bolts to the frame. Pull the stator cover and make sure the stator is not corroded. If the headlight and tail light bulbs are burned out you may have a bad voltage regulator (this only affects the lights, not the ignition).
2011 EC250E |
New 2006 200 EC | singl003 | New Bikes | 8 | 03-29-2013 12:53 PM |
Ec 200, 2006 | Pepperami | Enduro Engine - 2 stroke | 3 | 09-05-2011 08:29 AM |
