#11
someone must know something looking at the parts list it looks like the counter balance shaft is driven direct from the crank by a cog held on with a woodruff key and nut.. if i remove the cog will the counter balance shaft slide out from the fly wheel side??? and will i then be able to change the bearings and seals?
#12
To anyone interested you do not need to split the casings to remove out put in me counter balance bearings/seal you just nees a heat gun and some thing to knock them out with.. May take 10 mins with the heat gun but beats splitting the cases for no reason. I made a slide hammer up using a bit of pipe a few washers and a raw bolt which was enough to pull the bearings right out with a bit of heat.. Anyone taking this task on and wants more info im more than happy to help.
