Old 10-29-2019, 06:38 PM
Harty89 Harty89 is offline
Default Technical Bulletin - Crank and Flywheel Nut
Info from GasGas Australia Regarding defective Crank pinion locking nuts and a note about the flywheel nut. See attached PDF
Old 10-30-2019, 12:29 AM
rodent's Avatar
rodent rodent is offline
What's the consensus, take the steed back to the dealer or do it yourself?
Old 11-01-2019, 01:22 PM
I received a call from my dealer and brought the bike in. Mine had the wrong nut and the dealer replaced it.
Old 11-03-2019, 03:13 PM
Depends what's easiest for you, and your relationship with the dealer.
I need to check my VIN. Does anyone know if the crank nut has changed over the years? Namely the thread pitch? I have a spare one from around 2013 that I ordered.
Old 11-09-2019, 12:00 AM
rodent's Avatar
Gonna book it in this week and drop off hopefully. The dealer and I have some history, I'm not sure how it's gonna play out. I'll reply with the outcome
I'll ask about the nut while I'm there.
Old 11-11-2019, 02:38 AM
Spanish Christini Spanish Christini is offline
Subscribed.
Old 11-15-2019, 06:22 PM
rodent's Avatar
I dropped the bike off at the dealers yesterday, dealer told me that Gasgas have zero stock of the nut that may need to be replaced. I've since bought one elsewhere should mine need to be replaced.
Jakobi, dealer told me that the nut is the same for the 2013.
Old 11-16-2019, 12:27 AM
Why didn't we see any failures on other models if they have been using the same nuts I wonder??
Old 11-17-2019, 11:19 PM
rodent's Avatar
Crossed wires, the dealer told me that the 2103 nut that you bought is the same as the one that needs to be installed on the current bikes.
It should have the groove cut into the corners.
Old 11-18-2019, 05:16 AM
That makes more sense!
Where can I buy one of these 2103 models?
KYB technical touch USA website GG221 Enduro Suspension 0 06-14-2019 08:03 PM
Post your hard technical trails here hawaiidirtrider Pictures & Videos 29 05-11-2013 12:07 AM
Please use the Technical Forums for specific questions MattR General Discussions & Announcements 1 01-14-2008 07:24 PM
Website/bulletin board downtime possible. webmaster General Discussions & Announcements 0 12-14-2006 03:56 PM
Bulletin Board Upgrade... webmaster General Discussions & Announcements 0 08-27-2006 09:46 PM
