#11
You need to remember there are two sides to ever story. I was surprised by that story you mentioned so I did some additional searching and I actually found a response from Eric on another site and it painted a very different picture of the situation.
I have been sending work to Eric Gorr for the last 10 years he has always been professional, knowledgeable, and I have found his work to be very high quality. |
#12
Regarding my the piston life in the 327. I am about 3 years (`45hrs) into my second piston. I believe I had about 80 to 100 hrs on my first one. It started to get a little louder so I replaced it. I have been running Klotz R50 oil.
#13
Thanks for the replys I will look into this,how much are the Pistons as I guess they are custom made ? |
#14
The 76mm piston is a Wiseco and I believe it is big bore piston for an Honda ATC250. As I recall it was <$200.
#15
It is not an isolated incident. Before the GG riders club member had trouble and reported it here - I had personal knowledge of a cylinder that came back "destroyed" by Eric Gorr. Gouges in the cylinder walls (got wild with the die grinder/porting tool) , the power valves "had the shit ground out of them" and required replacement. Gorr eventually did supply a used replacement cylinder and power valves - but it took a bit for him to answer phone calls. Only after I told my friend how to block caller ID did he start to pick up the phone. (He wouldn't pick up the phone if he saw it was my friend calling about the damage he had done...) jeff
I am sorry to hear your friend had a bad experience. The work Eric has done for me over the last 10 years has been great and I will continue to use and recommend his work.
Pwk 36 oval-bore | stian | Enduro Intake/Carburetion - 2 stroke | 1 | 02-24-2015 12:32 PM |
Big bore kit 144cc | gasgasman | Enduro Engine - 2 stroke | 5 | 02-16-2012 06:12 PM |
does anyone make a big bore kit? | seamonster | Enduro Engine - 2 stroke | 9 | 01-21-2012 09:05 PM |
big bore 200 | jimbolaya | Enduro Engine - 2 stroke | 0 | 02-25-2010 09:40 AM |
