I love my Gas Gas but?
So, I've had my 08 300 about 8 months now and had time to get to know the bike pretty well.
I love riding it and in this area I have almost nothing to complain about! I ride some fairly nasty stuff so the bike gets a good workout on every ride. I love the power, I did add a FWW which aided in traction thru the greasy roots that litter our local trails. Did some minor changes to clean up the overly rich jetting . Handling is awesome, light, nimble, tracks well and the ergos fit my 5' 9'' frame well. Suspension was a little harsh front and rear, but I was able to sort that out with a re-valve, I like that the marz forks and sachs shock were easy to work on. So far the bike proved to be very reliable, in the 8 months I had to very little to do but clean the air filter and change the trans oil. So, what's there to complain about...mostly Fit and finish ! "Are you listening Gas Gas?" Here's my don't likes: 1. notchy shifting: It's not bad, just not as smooth as I'm used to (Honda/Yamaha) 2. squaky clutch: That dose bug, it's not constant, mostly under a heavy load 2nd 3rd gear. 3. Brittle plastics: They crack easily and don't hold up to impacts well 2. Gas tank shroud mounts: Get rid of the cheap wood style screws that screw directly into the gas tank plastic, this is very Ala-Chinese cheapo style ...follow the top 5 manufactures mounting design. 3. Using nuts on the back side of so many mounting bolts: What a complete "pain in the ass" to work on sometimes...take the sub-frame mounts...getting at the nuts of the upper mounts with a wrench is a hassle. Would it be so hard to add a nut welded to the back side of the frame on some of these mount points?? I mean GG builds a bike that is so close to anything else on the market...but in my opinion...then drops the ball on areas that are very crucial to the consumer and probably not that much more in cost to add to the manufacturing process. In any case I'd pay more for a bike that had better fit and finish. 4. head bolt sizes: Ok, would it be so hard to use common sizes, 8mm, 10, 12, 14, 17, 19, the bolts on my bike are a guess, I'm constantly running back and forth for wrenches...13mm, 15, 16, 18 etc... what the bloody hell. 5. Lower chain guide: The lower tension-er style guide is too prone to damage, I think it's a weak point and don't see the advantage over a the style every other manufacture uses. Conclusion: So, in reality this is a very short list and not that big of a fix for the manufacture but is the difference between GG and a top Japanese bike. Fit and finish is something that is very crucial to a owner and prospective buyer. First thing I noticed when considering a GG was the cheap wood screw shroud mounts, as well as backing nut plates on just about every bolt. So, I'm thinking what other shortcuts were taken? Fortunately, everything else seems solid. I wrote this because IMHO GG is so close but yet so far! I say to GG take that last step ...add the missing fit and finish and climb to the top! |
my 09 ktm 250exc uses screws to hold the shrouds onto the tank.
gas tank shroud mounting is surposed to have changed for 2010 models?
Buy a 4 Banger Honda so you can revalve it in 1000klm.
Adam 2006 FSE450...Gone 2011 EC300e Sunshine Coast, Queensland Australia |
Been there done that,between 2004 and 07 I raced three 450's and one 250, actually only the 250 needed a valve job with 150 hours...if that's what your refering to.
Besides, I think your missing my point. Just because Honda had some valve issues on their early F's does not negate what I stated in the thread...everything I said was valid. I'm just saying GG could refine what is already a great bike...with just a little more design effort on their part and give it that fit and finish it's missing in some areas. |
Have you had a problem with the chain guide ? or just dont like how it looks ? I've yet to have a problem with one.
Dont follow me, You wont make it. |
I'm with ya' on the hardware thing. Holy crap, how many wrenches should you have to use? The mismatched hardware is almost embarrassing.
Other than that, pretty dang happy. Actually like the use of Nylocs to back up bolts, mush easier to change than a gnarled up captured fastener. Try different tranmission oils, found one that improved shifting and quieted the clutch down. Chain guide - non issue. I changed every stock one on every other bike I owned as they are all crap.
Frank Staley President in Exile-Arizona Trail Riders "You live more in 5 minutes on a motorcycle than some people do in a lifetime" - B. Munro |
All these are valid points. As someone who was trying to sell GG's for years, I wish they would listen. Pointing out that there are other bikes that have problems to, is not the point. Those other bikes are what people are used to, they are going to get a pass on many of their problems. GasGas has to be better, especially if it's not going to be cheaper. The European mentality of "we build a great motorcycle and everyone should buy it regardless" is the problem. Americans need justification for their purchases. I've even seen the bike get blamed for the lack of mechanical skill by the owner, where if it was a Honda he would have blamed himself for that broken bolt or the engine that blew because it never had a top end.
Dan |
Yes the Gassers have faults but is it really any worse than any other manufacturere's? Cheers
Why I love my GasGas | Lex P | GasGas Member Polls | 61 | 12-06-2010 07:24 PM |
Gotta Love It | Rick | Pictures & Videos | 1 | 05-04-2010 05:59 AM |
I love my Gasser - again.. | stay_upright | General Discussions & Announcements | 7 | 07-16-2008 01:40 AM |
I'm in love | SpeedyManiac | General Discussions & Announcements | 0 | 03-26-2008 12:23 AM |
I think I'm in love | SpeedyManiac | General Discussions & Announcements | 3 | 06-17-2007 11:47 PM |
