#31
Did try the 42 bike was has to start, a/s did nothing
for me that's defo to big 38 is perfect
03 ec300 honda cr500 94 |
#32
Cooling off now with fall coming 10C (50F). Rode on Monday with a 42 pilot, N3CG #3, AS 2.5 turns out. Very strong off the bottom, I run the stock 13 - 48 gearing and had thought about adding teeth to the rear. Not now, it will pull from way down low in 2nd, 1st gear takes a steady throttle hand in the tight stuff.
06 EC 300. |
#33
Ok, I'm on 40 pilot, N3EG top clip, and 172 main.
If I run any lower than top clip (go richer on needle) I get loading up issues. 38 pilot loses all low end, feels perfectly crisp and powerful on 40, everything feels perfect. All I really want to know, is what needle will give me the equivalent of N3EG top clip, but in middle clip? Thanks!!
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#34
Thanks! So there is no 'just change 1 character' fix then
#37
No, The leanest version of that profile is an N82x, which is 1/2 clip position leaner than the N89x. Unfortunately the leanest starting diameter I could find was a K, so that isn't of much use to you. The N89G is, I believe still available though through Kawasaki http://www.partzilla.com/parts/detai...6009-1744.html and Yamaha, http://www.partzilla.com/parts/detai...916-9G-00.html help you out a little.
#38
I've Googled N3GG and it exists, recon this might be half a clip leaner?
#39
In 1/2 clip variations from leanest to richest they are...
N89x=leanest N3Cx N3Ex N8Rx N2Zx N4Dx N3Vx N4Ax N6Mx=richest |
#40
I've ordered the n3eg and a 180 main but don't see anyone using a 180 , is this too big ?
Just need to test it love , only be a hour |
ec 300 cck needle | alun | Enduro Intake/Carburetion - 2 stroke | 3 | 12-29-2011 02:53 PM |
needle | jimjim | Enduro Intake/Carburetion - 2 stroke | 4 | 07-23-2011 07:07 AM |
CHN Needle | nsgasser | Enduro Intake/Carburetion - 2 stroke | 3 | 05-21-2011 11:18 PM |
CCK needle | pevs | Enduro Intake/Carburetion - 2 stroke | 2 | 02-25-2010 02:04 PM |
