Gear shift shaft question (again)
I have all the parts to replace my bent shift shaft. Where does the white plastic donut called the selector axis go? I didn't see one when I removed the bent shaft. Any help greatly appreciated, also any tips on putting the seal back in the right way.
Thanks, Jim |
It goes behind the shaft seal on the shifter side-basically some sort of oil slinger to keep oil away from the seal.
That's my opinion from a few tear downs I've done in the past. The slinger is still in your engine case. |
Shift shaft
Will the old one in the case cause any damage? Splitting the cases is not in the plan. I don't have anyone to do it anyway other than send it to GoFasters, and they just rebuilt it a few months ago.
Suggestions? Jim |
I would pull the seal out and try to insert the rod through the existing axis.
Unless, you can see the axis through the seal opening. |
Shift shaft problem
No sign of the selector axis, she's going back together as is. Just noticed that little piece of plastic I can't use cost me $75. If the gearbox screws up that's the way it goes, it's a 2001 anyway. Any other suggestions welcome other than splitting the cases.
Jim |
You can try laying the bike on it's left side and using a coat hanger to fish around for the axis. You don't want that piece floating around in the transmission.
shift problems.. | stainlesscycle | Enduro Engine - 2 stroke | 1 | 05-11-2010 06:25 PM |
Shift shaft problems- continued | Trailrider | Enduro Engine - 2 stroke | 10 | 03-17-2010 12:34 PM |
Transnission shift shaft. | Trailrider | Enduro Engine - 2 stroke | 15 | 02-28-2010 05:10 PM |
Gear Selector Shaft Bent? | iancp5 | Enduro Engine - 2 stroke | 11 | 03-29-2009 04:39 PM |
Kickstart shaft question | GMP | Enduro Engine - 2 stroke | 6 | 02-22-2009 02:55 PM |
