short clutch lever
any recomendation???
i miss to my short lever from the Magura on the KTM as the AJP lever is longer, the two finger which left on the bar during the operation get press. is the folowing lever will be good to my ec300 2011? http://www.ebay.co.uk/itm/AJP-REPLAC...item1c19cea7d7 |
Yes, that will fit. Those cast levers are much more prone to snapping than bending, I broke one through my handguards.
There is a factory option short ajp forged clutch lever, but its rather expensive. |
The Zeta levers are the best I've found, short, adjustable and great feel.
I always just cut mine long enough for 2 fingers. No knob on the end may mean trouble at scrutineering, but I have not had any problems so far.
Barry 07 EC250 |
thanks for the tips!
I start with the cheper suggestion ( cut the end lever) if i will not like it, i will order a shorter lever. |
Any short levers available for the Gassers and how do you use your clutch? | stay_upright | Enduro Chassis & Body | 13 | 08-14-2008 04:06 AM |
clutch lever to big | rupecopp | Enduro Chassis & Body | 3 | 06-09-2008 05:15 AM |
$ 30 for a clutch lever ? | fasternat | Enduro Chassis & Body | 1 | 09-21-2007 12:01 AM |
