Coolant leaking through cylinder head socket-head bolts.
Curious to know what to do. I just put the bike together and have ran it about 3 times for a few minutes each. I've had leaks at the coolant lines and have replaced a few hose clamps. The hoses are brand new. Then I noticed coolant collecting around one of these bolt heads.
The bike has never had copper washers installed since I've bought it. Would it be as simple as that to fix? As far as I can recall, the studs thread between the two o-ring head gaskets into the cylinder, so it would make sense for coolant to be able to travel up these bolts and out by the heads. The gasket in the T shaped coolant return at the top of the cylinder is holding fine. Last edited by GGRider01; 10-17-2015 at 02:12 PM. |
Swopping 1997 Cylinder head with 2005 head | EC250 | Enduro Engine - 2 stroke | 10 | 12-15-2015 10:13 AM |
Help - Head Bolts? | liv2day | Enduro Engine - 2 stroke | 33 | 04-16-2014 09:33 PM |
Sealing Head Bolts -Coolant Leak EC125! | kevells | Enduro Engine - 2 stroke | 6 | 07-16-2012 01:26 PM |
Ec250 Cylinder Head Bolts? | Elliker | Enduro Engine - 2 stroke | 8 | 01-24-2009 04:51 AM |
Head bolts - no access? | eff | Enduro Engine - 2 stroke | 14 | 04-12-2008 06:43 PM |
