2001 xc250 shifter shaft bent crossover for replacement
Splitting my cases and bent shifter shaft stopped me. Im gonna cut it off in order to remove.
Gofasters does not have shaft available in fiche. Will a kx shifter shaft crossover? What are my options for getting replacement piece? Sent from my DROID RAZR using Tapatalk 2 |
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
Will shaft from 2003 fse 400 work? Cant tell from gf fiche.
Same thing happened on my 97' when I tore it down for rebuild. Bent (shifter) selector axis would not let me split the cases apart. Had to cut it!
Steve Beane from Afterhourscycle got me the piece (just the selector axis it self) I needed no problem. FWIW, it's should be in the fiche at Gofasters, but it is called a selector axis. Look at the fiche for any year Gas Gas under "shift cam" part #19. |
Im seeing the assembly for $145.
Just got shaft from 03 400sm cheap from ebay. It looked like it would work. Sent from my DROID RAZR using Tapatalk 2 |
Shifter crossover | kendunn | Enduro Engine - 2 stroke | 1 | 05-19-2010 06:13 AM |
shifter shaft c-clip | flybars | Enduro Engine - 2 stroke | 3 | 03-09-2010 05:36 PM |
Gear Selector Shaft Bent? | iancp5 | Enduro Engine - 2 stroke | 11 | 03-29-2009 04:39 PM |
2000 XC250 CDI for a 2001 UK EC300 | krazy | Enduro Electrical & Wiring | 1 | 09-14-2008 04:58 PM |
