#11
I have the same bike and had a nearly identical problem.
changed from hi test pump gas to race fuel and it solved the problem 100% my buddy has a 04 and it had started showing the same signs and his was fixed with race fuel also. some have replied that im running lean but its not true. it seems that the oxygen or whatever they have been adding to the fuel makes it turn into a pos. ive always used the same motul 800 oil the only thing that changed was to use race fuel and that solved two GG just like yours
2002 Husberg FE650e 2006 GasGas EC300 2014 Sherco SER300 2014 Beta Evo Factory 300 |
#12
Ive taken down powervalve, blasting it, changing bearings and checking that the balls are in the governator or what not. I am in need for a new bellcrank-actuator arm. So if someone have one, or know a shop who do sell one, please speak up. This could mostly be an electrical problem, as in CDI, coil, but OK to check the PV anyhow I guess.
07` EC300SM. 09` KTM 250EXC. 70`CB350 |
#13
we have gas stations that sell race fuel from the pump, just like diesel or gas. im not saying youre pushing the limits of the fuel. im saying that I changed to race fuel and the bike rips again
#14
Never had any problem running 95 or 99 on mine...
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#15
Video of engine running, full throttle.
https://www.youtube.com/watch?v=xPVy...ature=youtu.be Tested new CDI, new coil, no change. Im taking the engine for a close up tuesday.
07` EC300SM. 09` KTM 250EXC. 70`CB350 Last edited by stian; 06-06-2015 at 09:31 AM. |
#16
So what was the final diagnosis?
'06 GasGas EC300 |
#17
thought I deleted this topic.
It worked 10min down the road. 3x0,5mm cylinder gaskets, head shaved 1mm, squish 1.6mm. AS1 with 178,40 pilot, N1EG, top clip, 1,5 turns out on the airfuel screw. Vforce reeds OK. New bellcrank, governator OK. New Br9eg. 25h piston withing specs, rings well within spec (0,30). PV without arm spins smooth as butter, new bellcrank arm, also spins nice wired up. There is needing some force to turn it thought, but it is normal. New oil, new fuel (ron 95). Cylinder good, all new gaskets. No smokey. New crank-seals, new bearings (hole engine). PV cleaned. Tried KTM working CDI, and I swapped out the coil, and the stator. Still problems. Going to change the carb out with a AS2 i have laying around. Hate this fu**ing bike
07` EC300SM. 09` KTM 250EXC. 70`CB350 Last edited by stian; 04-10-2016 at 11:08 AM. |
Gas gas catches fire! will not rev past 1/4 throttle | knocklife | Enduro Engine - 2 stroke | 12 | 05-06-2015 09:33 AM |
Bogging and top end | Capz85 | Enduro Intake/Carburetion - 2 stroke | 14 | 04-05-2015 10:56 AM |
carb probs .bogging/ hesitation | hippygary | Enduro Intake/Carburetion - 2 stroke | 4 | 09-12-2013 12:10 AM |
More wins this past weekend | Clay | General Discussions & Announcements | 1 | 04-19-2011 08:33 PM |
03 GasGas 450FSE Bogging down, TPS value? | ktownrider | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 12-12-2007 10:34 PM |
