Parts New/Used Components and All Bike Part Outs |
Needed - 2013 EC 300 Clutch Slave Cylinder
Hi All
I am desperate for help! I'm trying to find a new or second hand clutch slave cylinder for me EC 300. The part number is ME25632026 and by the looks of the workshop manuals was the same part from 1996 to 2014. My chain broke and tore up the casing. Now the fluid is just bypassing the seals. Please can anyone help with contacts, even overseas, that I can try order from. Thanks a million!! |
In my quest to keep my 2002 running as long as possible, i spent time with the parts fiche.
You can still buy a slave cyclinder for US$105 from Gasgas. I think that the slave cylinders from 2015 onward, although not AJP, will also work with your bike. The number of changes GG made to the engines of these bikes from 2002 - today is quite small. I was worried about parts availability, but "new" things should fit older bikes. |
You could also use a Rekluse slave, I believe.
PM sent. I have a slave cylinder in good working order from a 2011.
Sponsors: http://www.evolutionsuspensionproducts.com/ http://www.sportbiketrackgear.com/ Blog: http://www.speedofarrival.com/ |
Is it possible to convert clutch slave cylinder to dot4? | jan_b | Enduro Engine - 2 stroke | 7 | 12-19-2014 12:01 PM |
Will a KTM clutch hose fit the banjo bolt on my GG slave cylinder? | bondo | Enduro Chassis & Body | 7 | 12-11-2014 12:53 PM |
2010 250f clutch slave needed | CACTUSREID | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 01-30-2014 08:34 AM |
clutch slave cylinder hydraulic seal | Boodog | Enduro Engine - 2 stroke | 3 | 07-08-2013 05:45 PM |
Clutch Slave Cylinder Rebuild | newgaser | Enduro Engine - 2 stroke | 5 | 03-17-2012 08:30 AM |
