Old 03-04-2009, 01:41 AM
Gassey fan's Avatar
Gassey fan Gassey fan is offline
Cool Throttle cable / slide
Just enquiring as this is my first 2 stroke dirt bike is the slide in the carby supposed to shut completely when bike is at idle as throttle cable is adjusted all the way out no adjustment left i don't even have any free play on throttle
the bike is a stock 07 ec300
cheers Chris
Old 03-04-2009, 02:06 AM
stay_upright's Avatar
The slide should sit on the idle adjustment screw with the throttle closed. There should be a small amount of free play in the cable and throttle which allows for cable lengths changing slightly as you turn the handlebars.
As a test with the bike stopped open the throttle 1/2 way or more and release quickly you should be able to hear the slide hit the idle adjustment screw. Marshalls usually check for this when scruitineering at a race as well.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
Old 03-04-2009, 02:11 AM
Gassey fan's Avatar
cheers looks like i will have to buy a longer throttle cable as i have about a 3-4mm gap at bottom of slide
thanks chris
Old 03-04-2009, 02:26 AM
iancp5's Avatar
iancp5 iancp5 is offline
thanks chris
You sure it hasn't jumped out of the fitting? Most likely under the rubber boot at the twist grip. Lot of people wire that up as they are a bit prone to it and it makes riding very exciting when it jumps out.
Old 03-04-2009, 11:23 AM
Gassey fan's Avatar
stttting snuggly in fitting
Throttle Cable Mishaps carlg Enduro Intake/Carburetion - 2 stroke 11 01-24-2010 09:22 AM
Throttle Cable steve Enduro Intake/Carburetion - 2 stroke 5 02-14-2009 02:39 PM
throttle cable steve Enduro Intake/Carburetion - 2 stroke 5 02-08-2009 06:17 AM
Throttle cable dave948 Enduro Intake/Carburetion - 2 stroke 7 10-10-2008 04:16 PM
Throttle Cable Crossover Ed Ventura General Discussions & Announcements 8 08-29-2008 05:55 AM
