JD Blue or Red needle. 2011 EC300
So I have now rebuilt the top end on the bike and want to get jetting sorted better.
Which needle to go for. I have the JD needles and a N3CJ. Current temp is 10?c and wet. Sealevel to 1000ft Carb is 38mm AS2 Just want a starting point and a needle to go with. Thanks |
N3CJ/2nd clip
42 pilot 178 main
Dick Carnes "If ya run, you'll only die tired" 2019 EC 300 2018 GP 300 2013 XC 300 (sold) 2006 DE 300 (buddy has it) |
Yes! Sent from my iPad using Tapatalk |
Will this be ok for my temps?
OK I will give that a try. Out on the bike in the morning so hopefully will be ok.
Are the JD Needles any good then? |
I'm a fan of the JD needles, very smooth.
N3CJ is a little abrupt. Try all three and you decide.
15 GASGAS EC 250 19 Sherco SE 125R |
I ride a lot of tight single trail with big climbs so smooth is good I suppose. But that's all I really know is the JD blue Needle.
But like you said I need to try all 3. Just going to take a while to do as have lack of time setting up for each needle. |
Interesting. I found the exact opposite. My bike has the squish cut and is quite high on comp though. Maybe that's the difference.
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
So many variables I have sorted the jetting on 5 bikes and not one has the same settings. Trial and error is the only way. I know how I want the bike to run just a matter of finding the combo.
JD blue needle jetting advice AS1 carb | nknudsen | Enduro Intake/Carburetion - 2 stroke | 1 | 03-12-2014 11:28 AM |
WTB JD Jetting blue needle | nknudsen | "Wanted to Buy" & "Want To Trade" | 0 | 06-05-2013 12:38 PM |
Needle Comparison DDK vs NE1F vs JD blue | bally123 | Enduro Intake/Carburetion - 2 stroke | 0 | 05-02-2013 02:51 PM |
