Old 11-21-2019, 10:45 AM
Skavilla Skavilla is offline
Default 1998 EC250 Carb Issue
Hey, getting my old '98 EC250 back on the trail and am having a carb issue.
Since the bike had been sitting up for several years, I completely disassembled the carb, cleaned everything, and reassembled.
Problem: Fuel is leaking out of what I guess is an overflow tube. Constant drip, if not steady stream when the bike is running.
Anyone know what would cause this?
Also, does anyone know where I might find a replacement carburetor if I decide to go that route?
Thanks for your help!
Old 11-21-2019, 11:19 AM
Your float needs adjusting, or the float needle is bad.
Carbs can be found on eBay.
Old 11-21-2019, 12:10 PM
Float valves do need replacement from time to time.
Old 11-21-2019, 12:30 PM
nknudsen's Avatar
nknudsen nknudsen is offline
Fix the carb you have unless it's corroded beyond repair. Good luck!
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 11-21-2019, 06:00 PM
It might be the float but out of the 10 GG bikes we have (including two 1998s) we have never needed to replace the floats. My guess is that the needle from the needle and seat needs to be replaced and you can clean up the seat mating surface with a Q-tip and toothpaste chucked up in a drill.
Old 11-21-2019, 06:01 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Pretty sure it will be the float valve that is not closing/sealing properly.
Remove it and check the rubber tip, also inspect the seat that it seals into.
The float valve isn't expensive to replace.
https://www.frankmxparts.com/Float-v...-38-carburetor
All the best, Dave.
Old 11-22-2019, 02:08 AM
Only thing that stopped my mates 2010 leaking. Cotton bud trick not withstanding. Any PWK valve from a 125 + KX or CR will work.
1998 ec250 part out Kpo73188 Parts 2 05-03-2020 06:53 PM
Please help 01 ec250 jetting carb issue Marc02ec250 Enduro Engine - 2 stroke 0 02-25-2018 07:10 PM
Rebuilding the carb on a 1998 250 EC DirtyBrit General Discussions & Announcements 0 02-01-2011 08:40 AM
1998 Gas Gas ec250 pferreira1970 Enduro Electrical & Wiring 0 10-19-2008 11:41 AM
