School me on carb slide cut outs...
I?ve read a number of posts mentioning that the stock carb slide is ?ok?. Which would be preferred for street riding? How is one different from the other. How does it affect fueling?
I assume you're meaning slide cut, 5/6/7 etc. It has most effect at 1/4 to 3/8 throttle. The higher the number the leaner the slide. It helps the transition from pilot to needle and shapes the power a bit.
Once you have a good pilot jet, strong idle and a needle that performs well, the stock slide is fine. If you like the needle taper everywhere but it's a bit iffy off idle, changing the slide can clean things up. Keep in mind that any slide change might require a needle change.
2011 EC250E |
keinin carb slide | Whitey86 | Parts | 0 | 11-01-2018 05:53 PM |
Wanted #7 notched slide or a whole 36mm carb | roverhybrids | "Wanted to Buy" & "Want To Trade" | 0 | 04-30-2013 07:38 PM |
Slide Theory, Carb Models, and Jetting | Jakobi | Enduro Intake/Carburetion - 2 stroke | 37 | 10-15-2012 08:53 PM |
Old School Slide Show | Rick | Pictures & Videos | 8 | 12-29-2009 08:11 PM |
