Old 07-15-2019, 05:47 PM
Wypipo Wypipo is offline
Default How does my piston look
I just took my pipe off and look through the exhaust port. I see some vertical lines. Not sure if this is normal or not? I have not work on 2 stroke bike before.
About 50 hours on 2018 XC 300
File Type: jpg C005112E-7DA2-42FC-B1AC-5FC2C8F35E45.jpg (6.2 KB, 84 views)
Old 07-16-2019, 05:50 AM
What am I looking at?
The pistons come with a coating on them. It tends to wear down. The piston moves up and down, so any wear patterns will usually be like that. A gouge such will be more than visible.. You'll feel it.
Most people inspecting piston wear through the exhaust port will be checking skirt wear (bottom front face of piston) which will polish up and allow the piston to rock a bit.. Ring wear, which shows as carbon passing below the rings; aka blow by.. and the cylinder wear on the far side of the jug at bdc.
You should also have a nice coating of oil on the piston as you cycle it..
Old 07-16-2019, 07:17 AM
Davehuge's Avatar
Davehuge Davehuge is offline
From what I can see, it looks good.
Old 07-18-2019, 12:28 AM
Very small image, but seems to look good.
Piston after 60 mth. skiba_14 Enduro Engine - 2 stroke 5 04-06-2019 01:35 AM
Where to buy piston kit? 95jersey Enduro Engine - 2 stroke 8 05-27-2015 07:38 AM
what piston gassergrant Enduro Engine - 2 stroke 3 11-30-2011 01:55 PM
Piston A, B or C? wence Enduro Engine - 2 stroke 19 07-06-2010 12:46 AM
piston W8TSON Enduro Engine - 2 stroke 1 07-31-2009 12:25 PM
