Old 02-25-2019, 07:28 PM
GASGASCWB GASGASCWB is offline
Default Linkage bearings!!!
Hi guys!
The link bearings on the rear suspension of my bike are slack!
Too much slack!
But my bike has only 20 hours...
My mechanic said that this is happening frequently in the European premium bikes like KTM, SHERCO, BETA...
My GASGAS is the only one in the region, so he did not know how to say if this is also recurring in new GASGAS...
In my YAMAHA WR 250 1995 and in my HUSQVARNA 360 2002 I did not even remember that these bearings existed as durable as they were.
Has anyone also had this problem with link bearings so recently?
Old 02-26-2019, 10:55 PM
is it all of them or just the one at the bottom of the shock? This one always goes quickly if you don't grease it regularly.
I assume the newer bikes don't have the o-ring and washer seal setup. that system works awesome, but not sure what effect it plays on the suspension as it is quite sticky
Old 02-27-2019, 07:03 PM
On the bottom!
Grease?
20 hours?
Yes, old suspensons have a o-ring and washer seal...
Actual bikes do not have.
Business...
Old 02-28-2019, 01:44 AM
Anders Anders is offline
Originally Posted by GASGASCWB View Post
Grease?
20 hours?
Yes. Many bikes are delivered with almost dry linkage, swingarm and steering bearings. When you buy a new bike, it may be a good idea to take it apart and grease it. Not only Gasgas, but other makes as well.
Old 03-01-2019, 08:09 AM
Mine has 36 hours (EC 300 2019) all linkage bearings and the floaters are gone west. No rust but just defective
Old 03-04-2019, 01:53 PM
synergy seals used to make teflon bush replacements for the linkage, not sure if they still operate.
have had them in my bike for years now, only the shock bearing that i have to replace (the teflon bush was the wrong size so this one has been normal bearing)
Old 03-04-2019, 03:57 PM
I could get INA or SKF high quality bearings but I can't get the darn bushings. That would mean to buy a GG repair kit plus the high quality bearings. I couldnt find anyone who can offer the bushings alone
Old 03-05-2019, 10:27 PM
farmerj's Avatar
farmerj farmerj is offline
Doc, if you've already done the research - do you have part #s for SKF?
I haven't taken my linkage apart, but it might be worth putting in new bearings before my bushings wear...although isn't bushing wear due to the material in the bushing itself? If so, I might as well run the stock bearings until all need replacement.
Let's put this into a question - will high-quality bearings cause less wear to the bushings than the stock bearings will?
Thanks,
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 11-12-2019, 09:59 AM
eralha eralha is offline
Do you guys know where to find the kit for the linkage arm?
I have the kit for the rocker arm but can't find the linkage arm kit.
Old 11-12-2019, 12:04 PM
ROCKERM ARM REPAIR KIT EC 2018 BE32035CT-CLJ-1
LINKAGE ARM REPAIR KIT EC 2018 BE34035CT-CLJ-1
Fits 2018 and 2019 EC 300.
Swingarm & Linkage Bearings Hulle Enduro Suspension 16 11-10-2017 06:16 AM
Ec250 linkage bearings Scotty97 Enduro Chassis & Body 4 01-24-2016 11:29 AM
Ec250 linkage bearings Scotty97 Enduro Suspension 0 01-17-2016 04:51 PM
'12 Linkage and swing arm bearings seitz331 Enduro Suspension 4 11-29-2013 06:59 PM
