#29
A 22 crossover might be a bit small but OK to try. You could probably steal the 28 or 26 out of the main stack without it causing too much influence overall as well.
With the bleed stack just invert everything below the spacer. IE 16x0.1 14x0.3 14x0.3 CLAMP 20x1.6 SPACER Inverted stack 22x0.1x4 20x0.1 18x0.1 16x0.1 14x0.1 11x0.3 11x0.3 bleed ports around post. This will take the whole bleed stack out of the equation. The 2 11x0.3mm shims won't restrict the bleed at all. The rest of the inverted stack just maintains some height for the stack on the post. |
05 shiver valving | jasont1532 | Enduro Suspension | 6 | 11-11-2012 10:40 AM |
Sachs fork valving '10 300 | Bailey28 | Enduro Suspension | 16 | 10-18-2011 08:43 PM |
sachs fork valving | dh racing | Enduro Suspension | 6 | 03-24-2011 01:03 AM |
08 EC300 Fork valving | AdrenalineJunky | Enduro Suspension | 9 | 08-13-2010 03:58 AM |
