Old 12-22-2006, 01:09 AM
kim kim is offline
Default Enduro computer
I'm going to add an Enduro computer to my EC300.
Any brands that can be recommended, mounting issues.
Any comments appriciated.
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 12-22-2006, 12:13 PM
fury1's Avatar
fury1 fury1 is offline
heres what alot of guys use around here for a computer,watchdog 2000http://www.dugasengineering.com/,you can mount it directly to your top clamp,but I have another great product to mount your computer,watch,roll chart and your damper mounts under your bars,neat setup,cleans up everything as well www.ptenduro.com heres a picture of this setup on my 300( havent mounted my damper quite yet)
Old 12-22-2006, 12:14 PM
fury1's Avatar
Old 05-17-2007, 10:41 PM
Magellan Magellan is offline
Default I have an ICO Pro Comp
and am happy with it. I got it for under $150 on eBay.
My buddie has the Watchdog. Also a nice unit. One thing though is that the ICOs will auto calicrate to the course markers. The Watchdog doesn't do that (at least from what my buddy can figure out). I find that to be a nice feature.
I think the Watchdog is easier to use during a race becuase you get more info in a single display. With the Pro Comp, I have to switch displays to get the same amout of info.
The ICO Checkmate would solve that, but the Watchdog looks like a tougher unit.
In the end, they are all pretty good. I went with the Pro Comp cuase I could get one cheap and wasn't sure how much I'd really use it. I races all last season and got quite abit of use out of it, but will probalby only be able to make one or two races this year (long drives and gas getting $$$).
James
2004 EC300 -- LTR Stuff, RB Designs Carb Mod
2016 Africa Twin
1975 Honda CB400 F1 (X2, projects)
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 07-03-2007, 09:00 PM
Boomhauer's Avatar
Boomhauer Boomhauer is offline
I just got the checkmate XL same as the regular checkmate except that it does not have the infa red programing.
Eash to use and cheap!
Bikeless for Now
Thanks to Smith's Powersports 724-899-3375
www.smithspowersports.com
Old 07-04-2007, 06:50 AM
eff's Avatar
eff eff is offline
Cheap may be a stretch, how about less expensive?
Old 07-04-2007, 02:42 PM
Boomhauer's Avatar
Geez I did not know that I had to be politicly correct to post here.
Cough, cough, excuse me less expensive for you correct folks on here.
350 bones (Dollars) to be exact.
Bikeless for Now
Old 07-05-2007, 04:42 AM
eff's Avatar
eff eff is offline
LMAO. Please don't be PC.
Old 07-05-2007, 12:41 PM
Brian VT Brian VT is offline
I use a Watchdog also. Very easy to use. You don't have to enter the resets and speed changes in order. You can just enter all your resets, then frees, then speeds as they are usually given to you before race day. The 'puta sorts them by mileage for you. It's also very compact and easy to read at a glance. The maker tells his story on the website about not having the Autocal. Maybe he really doesn't have it because of a patent, but the bottom line is the second hand on the clock.
Old 07-06-2007, 06:47 PM
Bandit9's Avatar
Bandit9 Bandit9 is offline
I use the Pro Comp as well. I am used to it. It does the job. Never breaks. I paid $150 4 years ago. I don't see the need to change something that isn't broke. You can do just fine on a Pro Comp if you don't want to spend big dollars on the computer plus billet mounts.
Blanco
Current ride: 2009 WR450
Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F
Anyone own a Pacemaker Enduro Computer? rpduc Off Road Racer's Corner 14 07-22-2009 05:51 AM
Which Enduro Computer?? angrytim General Discussions & Announcements 13 07-17-2008 10:21 AM
