Old 08-26-2017, 02:35 AM
matanstolero matanstolero is offline
Default Ec300 2015 stalls on high revs
Hi guys, after 2 weeks that my ec300 won't run and left with open fuel valve it stalls on high revs.
On low and middle range it runs fine... only when I try to go up to the high range it stalls...
The carb tuning seems to be fine because it never happened before and I didn't change the the jetting.
Thanks for the help.
Old 08-26-2017, 03:26 AM
(F5) (F5) is online now
Stalls in common useage means stops completely. I'll assume you mean stutters badly.
1st off change the plug and consider the plug cap. Ignitions are so good these days its easy to forget plugs can have all sorts of odd faults.
Then clean the carb out carefully. Also check fuel line isn't kinked. In-line filters love to create these kinks in short lines. Check gascap breather.
Old 10-08-2017, 03:24 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Check what F5 has suggested.
Also...
Fuel starvation? Is the carb getting plenty of fuel? There's a gauze filter on the petrol tap inside the tank, remove/inspect/clean. Also check the fuel tank breather in the filler cap is working and isn't blocked, if no air's getting into the tank petrol won't flow out easily.
I assume air filter is clean?
Is the tail pipe clear? I've seen tail pipes blocked with wadding that's come loose. Bikes start but won't rev at high rpm as they can't flow the exhaust gas.
It's simple but can cause some strange effects!
Good luck.
Old 05-19-2018, 12:34 AM
GSGSBrian GSGSBrian is offline
Did you find the problem? I just bought a 2013 EC 300 that is doing the same thing and I am not sure what the problem is. It cuts out at high revs. I set my needle position to the third notch from the top. It was on the second.
Old 05-19-2018, 03:12 AM
Davehuge's Avatar
If it loses power over a few seconds and stalls, I'd be looking at a fueling problem, maybe fuel starvation.
If it stalls quickly/sharply I'd be looking at an electrical/ignition problem.
Good luck, Dave.
Old 05-19-2018, 08:29 AM
Dave Dave is offline
My '03 suddenly developed a severe break up in the mid range and would not rev high at all. Traced it to a failed voltage regulator.
A friend's '05 lost power, the engine sort of bogged in the mid range and wouldn't rev out. The power valve linkage had become disconnected (bolt fell out).
Good luck.
'15 YAMAHA WR250F, '75 YAMAHA TY80 Gone: '00 380 EXC, '03 EC300, '07 YZ250, '07 250 XC-W, '08 YZ450F, '12 CRF250R
Old 05-21-2018, 02:53 AM
Erm. . So the cdi doesn't use the lighting/ battery charge coils at all so no need for regulator. That would only be the case for a dc powered cdi like an Ignitech. (Not sure about very latest models).
The earthing point for the coil and frame is there though so it could have been the issue.
Old 05-21-2018, 05:33 AM
VilluEST VilluEST is offline
Maybe I'm missing your point but at least '14 CDI is built to use either AC directly from coils (no e-start version) or regulated DC (e-start version). The CDI is the same for e-start and non e-start. My e-start has the CDI coil output, but it's not connected, even though I have completely removed battery and starter.
Old 05-21-2018, 04:16 PM
The regulator had failed and was shunting full alternator power to the frame. I suspect this bothered the earth reference of the CDI. What led me to the regulator was turning on the headlight (which used some of the alternator output) helped the bike rev a bit higher. Simply disconnecting the power lead from the regulator solved the problem until I had a replacement regulator.
Old 05-21-2018, 08:18 PM
Haha. That's a cute fault.
Overheating on high load and revs only, what could it be ? poelinca Enduro Engine - 2 stroke 18 07-11-2017 05:45 AM
Really sputters at high revs now motopsycho87 Enduro Electrical & Wiring 11 11-14-2013 02:04 PM
Engine won't run at high revs motopsycho87 Enduro Engine - 2 stroke 36 08-28-2013 04:37 PM
Sputters at high revs... motopsycho87 Enduro Electrical & Wiring 9 06-21-2013 10:12 PM
Low speed high gear stalls in v.slippery conditions stay_upright Enduro Engine - 2 stroke 5 04-02-2010 12:48 PM
