Old 02-23-2014, 04:11 PM
djroggen's Avatar
djroggen djroggen is offline
The weight solves the power valve coming on too strong and just smoothed it out all over. Can't go wrong.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 02-23-2014, 04:24 PM
iamovru's Avatar
iamovru iamovru is offline
Thanks so much! I reached out to Mark at GF to see if he has any more of them. What is involved in installation? Is it really involved?
15 Beta 300RR Race
Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP!
2011 GasGas EC300 "Stolen By A Scum Bag"
2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels.
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 02-23-2014, 04:26 PM
celler celler is offline
I agree. I have one myself.
Old 02-23-2014, 04:42 PM
djroggen's Avatar
Default Calming down the EC300
Simple pop off the cover, use an impact to unbolt the nut. Set the weight on the flywheel and bolt the new nut back on. I would recommend putting a 2nd gasket to ensure the weight does not hit the cover. With correct tools it's a 10 min max job.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Old 02-23-2014, 04:56 PM
iamovru's Avatar
Great!
Thanks again
15 Beta 300RR Race
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 02-23-2014, 05:30 PM
That 10 minutes includes time to have a beer
Old 02-23-2014, 06:02 PM
Rick's Avatar
Rick Rick is offline
Celler I'm really surprised you did not mention the fww earlier....
I am getting a 3honey to my stable very soon........so I've been paying attention to this type of threads!
Please let's us know which direction you go!
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 02-23-2014, 06:59 PM
pscook's Avatar
pscook pscook is offline
Do any of the FWW fit on the E-Start bikes? I thought the ring gear was in the way of the FWW on the flywheel.
Phil
(New bike pending...)
Old 02-23-2014, 07:23 PM
iamovru's Avatar
UGH! Well that would be a problem I have an estart
15 Beta 300RR Race
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 02-24-2014, 01:48 AM
Whats all this talk about calming it down?? Drop 50ccs and you'll calm down the bottom to mid.. And then retain a whole lot of 2T excitement above that.
Everythings a personal preference and there is no right or wrong way about it.
Dropping the compression will reduce bottom end snap of the big beast, as will raising the cylinder and port timing. You can do both for the price of a base gasket or two with the only downside being you'll open the squish clearance up and lose some efficiency, again taming it down.
Taller gearing can mean less changes and really smooth out the delivery too. The 300 has enough grunt down low to chugg on, so if you're not riding goat tracks that require changes back to 1st too often this is an easy change. A front sprocket is also cheap and easy to change and evaluate.
Retarding the ignition timing. Free and easy, and reduces the low to mid bite.
G2 Ergo throttle cams. Really work well to reduce the sensitivity of the throttle in that first half a turn.
Flywheel weights. Add some stalling resistance and smooth the whole rate at which the engine spools up and down.
calming the hit down.... stainlesscycle Enduro Intake/Carburetion - 2 stroke 13 04-10-2011 06:05 PM
2005 EC300 vs 2007 EC300 alecsstefan Enduro Engine - 2 stroke 19 01-22-2010 01:40 AM
