Old 03-15-2021, 01:41 AM
brads1725 brads1725 is offline
Default KYB Crossover
Hi All,
I have read that the reiger racing shock spring is the same as a KYB, anyone has any parts crossover listings for the springs/weight in KYB?
Looks like mine is a bit soft for my at 90kgs, but having trouble finding a reiger one.
Cheers
Old 03-15-2021, 01:59 AM
Anders Anders is offline
Originally Posted by brads1725 View Post
Hi All,
Cheers
Where are you located? You can buy springs directly from Reiger, they are not very expensive (I think I paid 80 Euro).
Old 03-15-2021, 01:30 PM
farmerj's Avatar
farmerj farmerj is offline
Another idea to add, I recently ordered a spring from Cannon and it got to me within a couple of days. $119.
Get out your caliper/tape and measure your spring I.D. & length, and they will likely have what you want in stock.
(Try a YZ250 match, 59mm x 270mm. This was 10mm longer than my stock spring, but it fit just fine. Also, if you haven't measured a spring before recognize that the top and bottom I.D.'s are slightly different, in this case 59mm is the smaller end).
Be aware that they measure their spring rates by Kg/mm, and GasGas (at least in the 2018 manual) uses N/mm - which is slightly different. You want to make sure you're getting the new spring rate you want!
Jeff
https://www.cannonracecraft.com/contact
405-524-7223
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 03-15-2021, 07:20 PM
I'm in NZ, so pretty far from all the parts.
Do reiger have a parts listing or do you need to get in contact first?
Old 03-16-2021, 02:13 AM
I can send you their parts list if you send me your email address via PM.
Reiger can be contacted via info@reigersuspension.com
Old 03-16-2021, 07:40 PM
tried to PM, did it come through?
Old 03-17-2021, 01:57 AM
Yup. Did you get my email?
Old 03-17-2021, 01:40 PM
Got it thanks. Hopefully I can get a spring in the 85-90kg range now. Also after the bearings at either end of the shock.
I have read the bush and needle roller are not "needed", anyone replaced them with anything else? I just put new rose joint swivels in but there is play in the upper due to the bush being worn. The needle bearing is new as well, they are 6 bucks locally but cant find the bush to replace
Cheers
Air filter crossover adv rider Enduro Intake/Carburetion - 2 stroke 3 04-30-2016 09:36 AM
Gas cap crossover forgiven General Discussions & Announcements 3 09-07-2014 08:19 PM
Crossover Rabbitist General Discussions & Announcements 1 01-25-2012 09:16 AM
Crossover-KTM Rads ? husley General Discussions & Announcements 2 04-10-2011 07:28 PM
Gas cap crossover help hotshot Enduro Chassis & Body 1 03-01-2011 08:35 PM
