Old 09-29-2015, 01:28 PM
Default Is your Carb Level?
My son's 250 was running out of fuel at high rpms even after I set the float height correctly. To make a long story short, I realized that the carb was not mounted level. By eye it can be difficult to set the carb level because it is on two separate angles relative to the engine.
With the bike on a stand with the tank off I put a construction level across the frame. I shimmed the bike to make it level. I then put the level on the top of the carb and found that what I thought looked correct was far from actual level. That angle prevented the carb from filling the float bowl completely and caused it to run out of fuel at high rpms. I initially had the carb tilted outward and to correct the problem I needed to rotate the carb top away from me (towards the center of the bike). This small change fixed the problem.
FYI- when the carb was set level the cable was in contact with the fuel tank.
Old 09-29-2015, 03:15 PM
Selvagem Selvagem is offline
Also I've been through this situation. In my case, I first installed the carburetor in its proper place on the bike, done that, with the help of an inclinometer, checked the result. After this, I adjusted the float level in the same inclination that I have when the carburetor is installed. To see the results, I used a transparent hose adapted to the tank drain plug, as indicated in this link:
http://www.gasgasrider.org/forum/sho...ight=float+set
I can say that the result was excellent, it does not leak fuel and have no high RPM missing problem not in a position to high requirements.
GasGas EC 250 2008
Equipped KYB SSS Fork.
Shiver 45 oil level? motopsycho87 Enduro Suspension 4 11-15-2014 02:56 AM
simple carb fuel level tool Gasgasogeros Enduro Intake/Carburetion - 2 stroke 19 01-08-2013 01:11 PM
09 EC 250 Oil level bossmans kid Enduro Engine - 2 stroke 2 03-28-2012 12:22 AM
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
WP Fork Oil Level MattR Enduro Suspension 11 08-02-2006 10:40 AM
