Old 07-29-2017, 10:03 AM
Rampart Rampart is offline
Default 2011 EC300 48mm Sachs Fork Seals Needed
Hi all
The local seller offers me a set of two oil seals and two dust seals for $ 75 on my fork. Maybe there is some options - for other bikes, and other forks (48х57,9х9) what selling cheaper?
Old 07-29-2017, 05:16 PM
dewenduro's Avatar
dewenduro dewenduro is offline
SKF kit
http://www.motocrosscenter.com/shop/...rks-sk48z.html
Old 07-29-2017, 07:11 PM
Any KYB 48mm seals will work.. I find OEM Honda 09 CRF450R (not X; they use 47mm showa) are the cheapest for genuine KYB.
Old 07-30-2017, 12:42 AM
80euro for seals and bushes
https://www.extracross.com/Suspensio.../Revision-kit/
Old 07-31-2017, 02:02 PM
Strange, all balls answered that this seal has size 48x58.4x9.8
http://www.allballsracing.com/55-132.html
They are quite different from my size (48х57,9х9), how can thay fit?
Old 07-31-2017, 04:23 PM
SKF fitting guide
http://www.jwtimports.com.au/downloa...ring-Guide.pdf
48mm ZF SACHS 48 x 57.9 x 9
48mm KAYABA 48 x 58.1 x 8.5
0.2mm difference in OD just means they need a little lube when seating the seal, and a little heat helps get them back out. 0.5mm depth makes little difference overall, especially considering the snugger fit.
I have used the OEM Honda/KYB seals in my Sachs for 300+hrs. I wouldn't use all balls fork seals if you gave them to me for free.
Old 07-31-2017, 04:27 PM
That link you posted: http://www.allballsracing.com/55-132.html
Shows fitment for Beta as well (all running 48mm Sachs or 48mm Marzocchi) as well as a big handful of Gas Gas bikes.
Old 08-04-2017, 07:10 PM
rvktm rvktm is offline
hi jakobl are the kyb seals you use twin spring type like skf
Old 08-05-2017, 04:19 AM
I'd have to check. Have a set here. Same seals that come OEM in Yamaha and Honda KYB's. I've found they last well, don't have issues with stiction (but not as smooth as SKF), and the price point is where it should be. SKF is a very expensive option. I usually run a set of SKF through for their dust wipers, and then couple them up with the KYB seals. Good combo.
Old 08-09-2017, 01:45 PM
So i got these ones
15$ pair
Fit good. Has one spring.
WTB 48mm Forks 2011 EC300 Needed Now GasGasRider "Wanted to Buy" & "Want To Trade" 4 07-21-2015 08:26 PM
2009 EC300R 48mm Sachs Fork Seals andyec300r Enduro Suspension 4 03-18-2013 10:19 AM
Fork seals on a 2000 EC300 - help please UK BazzabikesMK United Kingdom 5 07-05-2011 12:47 PM
Help Needed! Looking for Sachs Fork Expert in NZ EtienneNZ Australia & New Zealand 21 04-11-2011 04:05 AM
2010 Sachs Fork Seals Bradz Enduro Suspension 7 01-04-2011 12:06 PM
