Old 08-07-2014, 03:43 AM
imsimon imsimon is offline
Default struggling with wheel bearing change
Hello
im quite happy with changing bearings but im really struggling with the front.
The problem is I cant seem to get the axle tube to move to allow me access to knock the bearings out. Anyone got any tips that might help. Ive used various tools to try and get it to move across. It moves a very small amount but not enough for my punch to sit properly on the bearing
cheers
Old 08-07-2014, 05:02 AM
no tricks that i know of, just a sharp edge on the punch and keep trying to move the bearing with taps. eventually it will move enough to free up the tube
Old 08-07-2014, 05:33 AM
Thanks
typically. After I posted that I went back in the garage and managed to get them out. Like you say it just needed a bit of patiench to get on the bearings and once i did it was simple!
Old 08-07-2014, 06:03 PM
cbutler's Avatar
cbutler cbutler is offline
Ok here is a video of all the wheel bearing removal and install "secrets" Iv been using for years.
At 1.50 is how to move the spacer if you only heat one side at a time they will almost fallout.
Enjoy.
https://www.youtube.com/watch?v=y7GQI6Hh1bI
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 08-08-2014, 01:37 PM
Biff's Avatar
Biff Biff is offline
I use a kit that has inserts with a "v" groove. Pop it in bearing
Then use the wedge to expand insert against inner of bearing
(Using universal tool)
And out they pop
question on axle during bearing change imsimon Enduro Chassis & Body 4 02-16-2014 12:56 AM
Rear Wheel Bearing Rick Enduro Chassis & Body 1 07-14-2013 07:51 AM
Fork swap will I need to change wheel? gasgas1999 Enduro Suspension 10 04-04-2013 03:45 PM
Quick swingarm/linkage bearing change question motogroove Enduro Suspension 6 05-16-2011 12:58 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
