Old 03-17-2011, 02:56 PM
Woodsknight Woodsknight is offline
Default Changing Electric start to two kill buttons
Topic says it all. How do I get rid of the bulky estart/headlight/turn signal unit switch and replace it with a kill button and an Estart button. I bought two Yamaha style kill switches. I wanna put a kill button on the left side and a kill button on the right side (this will be used for the Estart button). I understand that I will lose the high/low switch for the headlight. I dont care about that.
Hope someone can shed some light. Thanks
2011 EC300e
Old 03-17-2011, 05:02 PM
Neil E. Neil E. is offline
Engine kill: Yellow/White wire is connected to Yellow/Green wire via your new button.
Engine start: Black/White wire is connected to Red wire via your new button.
This is based on the wire colours in the multi-function switch harness (at the connector socket). I assume you'll connect to these wires.
The chassis wiring plug has the identical colours. (edit: I checked to be sure)
Above info based on 2011 250XC with estart.
Old 03-18-2011, 04:19 PM
Thanks Neil!! Hey maybe you can help me out of another jam? Do you know the stock shock clicker settings (or ballpark) on the 2011's? I changed my rear spring and messed up the setting.
2011 EC300e
Old 03-19-2011, 09:20 AM
No idea on the suspension (I haven't looked at mine yet). The snow has only just melted here. Trails won't open for another 4-6 weeks. Are the specs somewhere in the owner's manual?
Old 03-19-2011, 10:28 AM
I couldnt find anything in the settings. I set it at 31 out. I think thats close to where it was
2011 EC300e
New 2011 Gas Gas EC 300 (Electric Start) onegreyghost General Discussions & Announcements 32 08-31-2010 07:23 PM
GGOR Questions : 2T Electric Start Specs & Direct Injection Neil E. General Discussions & Announcements 18 08-28-2010 09:54 AM
electric start 2 Banger Gas Gas Klausen Enduro Engine - 2 stroke 1 06-21-2010 06:19 PM
Electric Start EC300 J D General Discussions & Announcements 25 02-22-2010 03:12 PM
Kill Switch Dingo Enduro Electrical & Wiring 4 12-10-2008 04:23 PM
