Leaking fuel from overflow.
Hi all,
Since my last ride my 2013 EC300 has been leaking fuel from the carb overflow pipe. I was ready to remove the carb to give it a clean (or order parts if required) but noticed the hose in the attached photo was damaged. It goes from one port on the side of the carb directly to another port on the opposite side of the carb. I dont believe it is a breather as it doesnt vent to air. So two questions: 1. Can anyone tell me what the purpose of this hose is. 2. Would this hose being damaged cause the carb to leak fuel out the overflow? Thanks all in advance. Regards, Ryan Last edited by razza; 08-27-2019 at 04:07 AM. Reason: add photo |
Usually it's not hooked up like that. A separate hose would come off each barb and run upwards on the frame. Alternately they could be tee'd into a single hose that goes upward to vent.
I doubt hooking them together is an issue, but the float bowl does need venting so fuel will enter. You are only venting the float bowl, so all the connections are doing the same thing. Mine is teed to a single tube that goes to the top of the airbox. Fuel out the overflow is from a float level set too high or a float needle stuck open. Sometimes you can rap on the float bowl with a screwdriver handle and get the float needle to seat.
2011 EC250E Last edited by Neil E.; 08-27-2019 at 07:35 PM. |
chain looks like its seen some miles too
Had the bike been sitting for a while with ethanol gas in it?
Needle valves do just go bad. I would pull it apart and give it a quick cleaning and check the float height, and change if necessary, and inspect the needle carefully and replace if needed. If that doesn't fix it you you can try polishing the valve seat as they can get rough over time. I've had to do it before and saved me from pulling my hair out wondering why it kept leaking. Here's a vid showing how to do it... https://youtu.be/zlez_hdoWYk
2014 xc250 leaking fuel | Gas gas 1985 | Enduro Intake/Carburetion - 2 stroke | 3 | 10-02-2014 08:52 PM |
Leaking petrol from overflow | Stamper | Enduro Engine - 2 stroke | 5 | 05-14-2014 02:51 PM |
Fuel Leaking | Stef | Enduro Intake/Carburetion - 2 stroke | 9 | 10-27-2010 07:51 AM |
Leaking fuel lines. | Metalefty | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 10-28-2009 09:50 PM |
Radiator Overflow | geraldh | Enduro Engine - 2 stroke | 5 | 10-04-2009 09:23 AM |
