Old 05-07-2017, 07:34 AM
Rampart Rampart is offline
Default Red button?
Hello all
can someone explain, how exactly this red button works?
Old 05-07-2017, 08:03 AM
Cox76y Cox76y is offline
That would be which red button on which bike?
Old 05-07-2017, 09:37 AM
If you are talking about the Sun/Rain switch, it adjusts the timing curve on the CDI ignition. Sun mode makes more power and Rain is more linear with less hit in the power delivery.
Old 05-07-2017, 10:09 AM
Sorry
Old 05-07-2017, 10:14 AM
So, first of all - it make less power at "Rain" (noobe mode), or it designed to neutralize weather conditions to fit jetting?
My "rain" is Soooo rich...
Old 05-07-2017, 11:13 AM
The ignition timing is retarded in rain mode.
Last week, I accidentally bumped mine into rain mode.
The bike was a gutless wonder.
Old 05-07-2017, 12:38 PM
It sounds like your bike may be jetted rich and the rainy day setting highlights the issue.
Old 05-07-2017, 12:46 PM
it might be a little rich by main jet, but it's not an issue. And it run really good at "sun" switch. So i just don't understand what exactly "rain" i need for.
Old 05-07-2017, 04:59 PM
As above. It retards the ignition timing.. I set my engines up to run strong in the sun setting, and then that's usually where it stays... even in the sloppiest conditions.. that lever on the left hand bar works wonders to modulate power to the back wheel.
Old 05-08-2017, 02:13 AM
OK, thx
so it's no use for this button)
Start/Stop Button bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-21-2016 01:19 AM
Start button quits intermittently earlystock Enduro Electrical & Wiring 4 10-15-2014 01:20 PM
Push button air bleeder for 48 CC Zokes? Bandit9 Enduro Suspension 5 09-21-2013 07:31 PM
Why no back button GregM Suggestion Box 6 09-01-2011 02:10 AM
EC250 aftermarket kill button Leon_gasgas Enduro Electrical & Wiring 2 01-21-2008 02:59 AM
