#201
And what to run in shiver 45s prey tell?
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
#202
You can mix 5W and 10W (same brand) in order to archieve a custon oil
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
#203
Any one else have a brand suggestion that worked for them? So far KYB
Member of AMA, COHVCO, RMAR, Stay the Trail, COTPA Co-Founder of: TrailTaker My site: TrailTaker.com |
#204
Special swamp mix to get to 7.5wt
#205
Using this chart
http://www.mediaturbo.com/clients/ma...viscosity.html I went with the Maxima Racing Fork Fluid 125/150 as the specs are pretty close with the Marzocchi oil.
#206
I'll be using Amsoil 5wt which is a similar viscosity to the KYB 01 that twowheels uses. Seems the main thing here is to pick an oil and then tune for it.
#207
Motul has a 7,5w https://www.motul.com/es/en/products...ht-medium-7-5w
I use it on the 48's , great stuff
Vindicator '11 EC 300R |
#208
I am going to get into mine at some stage as I reckon the internal cartridge may not be bled correctly as I have a clunk which was not there before the forks were done.
Happy with the overall action but the clunk is annoying and when it occurs it feels like the fork is bottoming although the final inch of the shaft is not being used. Seems to me like I am not getting the full range and from re reading glenn's and others articles on GGforum it could be that the internal was bled like a KYB or Showa??? We will see. I will also be getting the shock oil changed and whilst there see if I need a heavier spring and better valving as the rear end kicks up quite a bit no matter what I do. Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
#209
Also the Fork cap I think you mean this, but is that the right size again I have no clue http://www.amazon.com/Wrench-Motorcy...ork+cap+wrench All I did was loosen the cap on mine so far, it came right off with a good adjustable plumbing wrench. A little worried on this octagonal socket deal you mention. But i think that is for taking the cartridge apart, am I correct? Again what size is that...I see plenty on Amazon but don't know what size to get.
#210
Oz Current. 2015 ec300r estart, 98 RM 125 2013 Ec300r 2011 Ec300e 2009 Husky TE310 1982 XR500 Honda 1981 KE100 Kawasaki 1978 GT80 Yamaha |
new 48mm Marzocchi forks?? | Dave A | Enduro Suspension | 19 | 11-04-2011 07:48 PM |
2004 ec250 ohlins forks, 46 or 48mm? | Mikeythefokker | Enduro Suspension | 1 | 04-27-2011 10:39 PM |
WP s or marzocchi forks | Stoby | Enduro Suspension | 2 | 08-19-2010 07:16 PM |
