EC300 exhaust
Goodday!
The exhaust of my '02 Gasser EC300 is not in the best shape anymore, Do exhausts of newer EC300 fit? On pics they basically look quite alike/the same. |
I put two different 2007 pipes on a 2003 GG300 and 2004 GG300. As I recall I needed to shorten the pipe slightly so the muffler would go on all the way and I think I needed to either slightly bend the pipe mounts and or drill a new hole to align with the lower rubber mount. I think one may have also needed a minor dent to provide clearance for the radiator bottom tank. It was relatively easy and I would not hesitate to do it again.
Thanks. Edit : What pipe is recommended for a bit more bottom end grunt? |
I would suggest a FMF Gnarly.
I have a reasonably straight gnarly for an 07 I could sell you for cheap
All I had to do was fit a new lower mounting rubber. One has straight, one has offset.
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
06 ec300 exhaust cat? | motopsycho87 | Enduro Engine - 2 stroke | 2 | 06-24-2013 06:54 PM |
ec300 exhaust pipe | RiverRight | Enduro Engine - 2 stroke | 2 | 08-01-2012 04:09 AM |
? on exhaust for 2010 EC300 | john01 | General Discussions & Announcements | 29 | 11-16-2010 01:33 AM |
EC300 exhaust note | BULTACOBRIS | Enduro Engine - 2 stroke | 5 | 04-27-2009 04:35 PM |
