Old 11-04-2015, 10:55 AM
wilson2 wilson2 is offline
Default gasgas ec 250 oil comeing out of tail pipe (new engine )
Hi guys
I have just bought a 250 ec 2 stroke with a melted mains so had all that done buy local bike shop new barrel new piston the lot
My problem is that now i have loads of 2 stroke oil comeing out of the exhaust i did have the bike running before the rebuild and did not have any oil comeing out then .
The bike pulls like a train nice power band loads of power all is gooď
can any one help?
Old 11-04-2015, 11:35 AM
12Bravo's Avatar
12Bravo 12Bravo is offline
Take a picture. Spooge is normal, same concerns I had when I got my first 2T.
What mix oil are you using?
How do you ride? This from what I have learned has a huge part of the spooge issue.
"There is no room in life for Regret, it's a useless feeling that leads to a negative attitude" I would rather call it the "Stupid Tax"!
Old 11-04-2015, 11:43 AM
nknudsen's Avatar
nknudsen nknudsen is offline
I wouldn't worry about it, pretty normal, she's a 2T. Did the shop put in extra premix oil to help the break-in? Once broke in you can make some adjustments (premix ratio and oil type, jetting etc.) to lessen the oil out the muffler.
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 11-04-2015, 01:37 PM
Default gasgas ec 250 oil from exhaust
It has at one time dribble on to the swinging arm i am running 5 litres of fuel to a 100 mm of oil or 5 to 1 is it worth clean out the pipe and a repack on the muffler
Thanks nick
Old 11-04-2015, 01:46 PM
Caravan Monster's Avatar
Caravan Monster Caravan Monster is offline
Assembly lube pooled in the crank case - it'll soon be gone. Also, the jetting might have been messed with pre meltdown to keep it running, and it might need changing to work right with the fresh engine (maybe accounting for excessive spooge)
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 11-04-2015, 03:30 PM
jostby jostby is offline
Thanks nick
Mine has always dribbled (very slightly) onto the swingarm but usually only if I've been doing slow riding a few times out then hit it hard the next time. It runs so good I've never messed with the jetting any more after getting it dialed in. One piston replacement in 14 years. Why mess with a good thing?
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 11-06-2015, 07:22 AM
eff's Avatar
eff eff is offline
Completely normal. Jetting changes can minimize it but not eliminate.
2004 GasGas DE250
Old 11-07-2015, 12:43 AM
Mick Mick is offline
What oil are you using? Did the shop toss some of their fuel in there? Might be different ratio/type than what you use.
One with a lower flashpoint will have less spooge.
For racing I'll run Motul 800 (high flash point)...good for running the bike hard, but for slow trail riding it will spooge. For slow trail riding I use Motul 710 with a lower flashpoint, no spooge.
2017 Beta 300RR
Old 11-07-2015, 01:11 AM
Capz85 Capz85 is offline
if your running the standard jetting spooge is usually an issue,once I started to use a different needle it stopped
Standard needle is crap throw it away
What is your favorite GasGas engine size? MattR GasGas Member Polls 51 09-11-2014 10:12 AM
who makes the GasGas txt 50 boy and ec 50 boy engine roverhybrids Mini Gasser 's Corner 5 02-15-2014 11:00 AM
Please clarify these GasGas engine truths. Mazikeen Enduro Engine - 2 stroke 19 04-16-2012 02:49 PM
gasgas ec300 engine problem jens Enduro Engine - 2 stroke 26 02-08-2012 01:36 PM
Engine/pipe/radiator protection for 09 ec300 jdosher General Discussions & Announcements 3 03-01-2011 08:41 PM
