#11
It had to be emptied first too! The things we have to do hey!
#12
How did it go? Inquiring minds want to know.
#13
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#14
Sorry for the late reply on this one.
So I have set the PFP to the soft setting at 1 turn and I have now got 3 weight oil in the forks. It is super plush now. On open roads with corrugations the front end doesn't give a twitch of feedback through the bars. In deep hard pack whoops the front end behaves well and in sand it still holds its height. I have softened the rear compression to the point I now get full travel in the rear (marks on the bottom of the mudguard) and then wound it in 2 clicks. The rebound on the rear I have had to slow down now but all in all I am so glad I changed the fork oil weight. Quick and easy fix to the harsh forks I had previously. |
#15
did you change the oil in the cartridges or just the outer tube?
2006 GasGas EC300 2011 KTM 300XC |
#16
Only the outer tube mate. I thought id try the simple steps first and then move on if I had to but overall I am happy enough with the changes I have made.
#17
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
#18
I only put in the 330ml which is 10ml more than the manual states.
About the MArzocchi 48mm shims stack settings | dsp | Enduro Suspension | 16 | 08-31-2018 08:26 PM |
Marzocchi 45 shim advice? | motopsycho87 | Enduro Suspension | 17 | 10-20-2014 12:47 PM |
Profile pic! | Pepperami | General Discussions & Announcements | 3 | 09-27-2013 12:30 PM |
2011 300 xc Ohlins shock shim stack | BrentMartell | Enduro Suspension | 6 | 04-12-2012 09:51 AM |
05 EC250 Marzocchi stock shim arrangement ? | ferguscawley | Enduro Suspension | 10 | 01-10-2008 07:49 AM |
