Old 10-22-2019, 02:35 PM
palec456321 palec456321 is offline
Default Gas gas ec 300 crank shaft nut
Hi i need help.
I did a general overhaul. I replaced the crankshaft seals. and when I tighten the nut (crank shaft pinion lock nut).there is the opposite thread. I found on the Internet that he needs to be tightened on 98NM. but when I tighten it to approximately 70NM .the crankshaft is very difficult to turn. should it be? can new seals do it?
Thanks for help. And sorry f?r my Bad english.
Old 10-22-2019, 06:24 PM
Originally Posted by palec456321 View Post
Hi i need help.
Did you split the cases? If so, I would check to make sure that the crank is centered between the cases. If not, you may need to hit the crank shaft with a mallet or brass hammer to get the crank centered in the cases.
Old 10-22-2019, 06:29 PM
You should not need much force with the hit.
Old 10-22-2019, 06:40 PM
Agreed, if a light tap does not do it, I would try and use another method, such as a crank installer tool to assist with the light hammer tapping.
If you hit it too hard you could force the crank out of true.
Old 10-23-2019, 12:41 AM
They generally always need a sharp tap.
Old 10-23-2019, 02:37 AM
As above, just eyeball the crank webs in the cases to make sure it is centred.
Old 10-23-2019, 10:07 AM
Have you installed the gasket between the case halves?
Sealer alone won't work.
Help crank shaft play andrewjtheis Enduro Engine - 2 stroke 10 05-15-2019 05:56 PM
GG FSE 450 crank shaft and other parts [rebuild] V1T0 Enduro Engine 4 stroke (including EFI & Exhaust) 8 10-27-2018 11:43 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
XC250 2001 Crank shaft Interchange Zman Enduro Engine - 2 stroke 3 03-12-2013 09:47 AM
2001 XC300 Crank shaft bearings timlh Enduro Engine - 2 stroke 0 06-23-2010 06:23 PM
