GasGas Riders Club Forum
Go Back   GasGas Riders Club Forum > GasGas Enduro Technical Forums > Enduro Electrical & Wiring
Old 08-01-2020, 09:57 AM
GasGasRider_ GasGasRider_ is offline
Default Battery problem
Hi, i have a problem with my Gas Gas ec-e 300 2014.
My battery wouldn t charge, light and other equipment work normal but on full throttle it start to bug.
Every information is helpful.
Old 08-01-2020, 01:13 PM
How did you find out that the battery isn't charged? Did you measure what voltage you have at the battery terminals when the engine is running and revved?
Old 08-01-2020, 01:21 PM
It is 12,80v all time, when i open light it fall on 12,45v
Old 08-02-2020, 03:54 AM
So it's not charging.
,measure the AC voltage from the stator. Should be say 50v ac. Then into rectifier..
'07 EC300
496 CPI Cheetah RZ/RGV hybrid
675 Street Triple R
RS125 framed MB100 racer
Stinger T125 Suzuki
Old 08-02-2020, 09:49 AM
Stator has been removed , does the engine have to run for examine it
Old 08-02-2020, 11:15 AM
Neil E. Neil E. is offline
You can certainly inspect it out of the bike, but it's got be in place to check the voltage output with the engine running. With it removed you can do resistance checks to see if any windings are "open" (broken).
Old 08-02-2020, 11:21 AM
Values here:
http://www.gasgasrider.org/forum/sho...e+measurements
Old 08-02-2020, 01:14 PM
What wire i need connect on multimetar? I put stator in bike and connect yellow and brown wire on multimetar. Voltage is 26v.
Old 08-02-2020, 08:02 PM
Been too long since looking.
So what wire connects AC to the rectifier?. Is there any DC output from the output and ground?
'07 EC300
675 Street Triple R
Stinger T125 Suzuki
Old 08-03-2020, 06:28 AM
Yellow and brown wire go to rectifier, white and second brown to cdi from pickup. And there is red and blue wire that go nowhere
Bike won't run without battery and won't charge battery memphis2857 Enduro Electrical & Wiring 3 04-28-2017 09:02 PM
Battery problem? tzsuzuki Enduro Electrical & Wiring 12 01-20-2016 10:18 AM
I bought a 2000 xc and keep finding problem after problem 675AZ Enduro Engine - 2 stroke 12 02-15-2013 07:25 PM
Battery for a 07 450? fastisbetter Enduro Electrical & Wiring 2 03-29-2011 08:06 PM
battery power problem GalenaGasGas Enduro Electrical & Wiring 3 04-15-2009 03:06 PM
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
