2001 EC 300 to dual map CDI?
I had purchased my 2001 EC300 previously loved. The gentlemen who owned it previously had done seemingly everything to get as much low end as possible at the expense of almost no power band.
How hard would it be to swap to a newer ignition mapping with the dual switch? I really like my bike and I would swap some grunt and chug for top end. I prolly have to swap out my carb too but I like the idea of a conditional CDI anyway. The carb comment was because it looks like it has a divider plate and I thought he said it was smaller for more torque so... Thanks |
* Install CDI from EC/MX200. I am in the UK and found one used from the states. This should really liven it up and give more everywhere. If you can go for a dual setup then great. I haven't gone that far and I don't do tight stuff. * Carb - I had to adjust float height and I installed LTR jetting kit. The divider plate only affects the low speed circuitry, so it is ok to leave in there. Is that the RB carb mod the previous owner has installed? RB installs a divider plate to keep the low end. Make sure your carb jetting is correct and isn't too rich up top (or too lean). * Reeds - if possible remove the reed spacer, and might need a longer carb boot. Make sure reeds are in good working order and get carbon fibre reeds for top end. Someone else will need to clarify this and suggest the correct part. * Definitely need a top end pipe - I have a DEP which is a high end pipe from UK. Other top end pipes are DOMA, Messico, and possibly the OEM pipe you may already have. Make sure muffler is packed correctly and in good working order. * Make sure power valve is opening all the way. * RB Mods - I am sending my carb and head in from the UK to RB. The carb will be bored from 38mm to 39mm plus other trickery, like the dividing plate. The head mod will increase compression which will keep low end torque as well, please be easier to jet. It is stupid good value for money, send it to him, unless already done. * Remove the flywheel weight. Also, if you don't need lights, or don't need good lightning, replace 2k3 ignition with 2k2 igntion which is lighter. Not sure if this would be worth it though. * Make sure everything else clean and in good working order, getting enough spark, good piston and ring, etc. Let me know how it goes, might be able to compare notes. And check out this link for someone who did the same: http://antithumper.700hp.com/gasserfly.html Cheers Krazy Last edited by krazy; 03-31-2011 at 03:26 AM. Reason: typos |
Your on the right track but unless you have enough base gaskets to ensure that the exhaust port is fully open at bdc you will just have a torquey'r diesel. I did all of the above, black cdi, ect and it still did not make top end power ,until, I did the port timing correction. This correction will absolutely require a head mod.It should be noted that i would'nt hurt to retard the timing for more over rev, Blitzy allmost certainly knows the cdi function @ what rpm is full advance, so you could use a timing light. My feeling is that for static timing, 0 mm btdc would be ok.
That probably runs nice, like a 250 with more all over, not all low end yank. Did you make a plate or just stack gaskets? How thick?
I didn't make a plate , cant recall off hand how many gskts but head had to be cut a 2nd time because I lost so much compression stacking gskts. My 011 allready had the exhuast fully open a bdc but had an outrageous 3 mm squish clearence as well. It was a bit of a crapshoot as I didnt know absolutely how the new 011 engine would behave with the delivered port timing and the stock jetting being so far off, but I have to say after cutting the head to 1.9 mm, jetting and a small timing advance it is very impressive. Allmost to much in the dry mode ,that being said on a tricky hillclimb on rain mode it will still collect itself nicely in 2nd from near stalling rpm, my beta 570 will fall on its face sooner than this 300.The same hill on dry mode and the addition of a g2 throttle has me fighting to keep the front end down I'm at my 200lbs. My buddy who's 300 lbs had his fat ass smartly hauled up the same hill on rain mode and was thoroughly impressed , that says alot considering his reg ride is a 550 berge. Impressed enough now he's suggesting to get his kid who's on a pro circuit kx 450 f to make the change. As a final point it should be noted that the head mod is'nt what turned the bike into a fire breather but a nessesary solid foundation to build my prefered power delivary characteristics on.
I want to get this bike properly sorted and don't want to leave anything on the table. I will need to take the bike to mechanic and say "do this", as they might not be "ec300-gasgas-with-black-box-cdi" gurus. I will go do more research but if you could help fill in the blanks it would be most appreciated. I have noticed your great posts on this forum over the past year or so I have been reading. This type of information is gold, thanks for sharing your knowledge and experience. Last edited by krazy; 03-31-2011 at 03:04 PM. Reason: typo |
ITs not all that difficult. You'll need a good selection of base gskts, get two of each thickness they'r cheap. Remove cylinder add extra gskts to raise cylinder untill exhaust port is allmost completly open @ b.d.c, Measure squish as per RBD , you'll need play dough as there is no solder that is thick enough. With those specs in place send the head to Ron for correction. I personaly would keep the squish between 1.75-1.9 mm, the reason for this is , if you find the power to peaky you can allways remove a gskt without exceeding the pump gas compression requirments. May as well have him do your carb while your at it. Good Luck and hang on.
Interesting stuff. Do you guys need to run race fuel after the RB head mod?
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
You specify original compression and desired fuel use and he sets dome volume to suit after the squish adjustment. About 200 PSI is tops for pump gas. Stock 300s usually run around 180 PSI.
I seen that original article before. Looked for a DOMA pipe in the USA and couldn't find any TOP END pipe for the 01 in the USA...perhaps I was just looking in the wrong spots.
Dual map CDI on 250 | GMP | Enduro Engine - 2 stroke | 32 | 01-19-2014 11:23 AM |
Dual Sport ???? | victorykid | General Discussions & Announcements | 3 | 11-17-2010 03:02 AM |
Dual Map switch.. | stevehipkiss | Enduro Electrical & Wiring | 3 | 01-28-2010 01:29 PM |
Dual Sporting a 2T | kendunn | General Discussions & Announcements | 0 | 12-18-2009 06:46 AM |
Dual Map on a 2001 EC250 | ducncover | Enduro Electrical & Wiring | 4 | 03-03-2008 03:42 AM |
