coolant fluid
Hello everyone
I got that coolant fluid. Is it proper to use it for my GG? Does it needs to be mixed with water or use it as it is? |
Yes, you can use it.
Looks like it is already mixed with water. Use it straight out of the jug. |
maybe just flush out your existing coolant:
drain, then flush with water, then fill with 50:50 mix of white spirit vinegar and water and run the engine for about 5-10 minutes. let it cool down, drain and flush again with water. then you are good to add your coolant
First coolant change - $#%+ In coolant?? | Why Z? | Enduro Chassis & Body | 10 | 06-26-2014 03:32 PM |
Oil & rad fluid. | kyton | Enduro Engine - 2 stroke | 7 | 05-19-2014 02:14 AM |
Brake fluid?! | 300ec | Pictures & Videos | 1 | 10-13-2013 08:37 PM |
Which Brake fluid? | Scar13 | Enduro Chassis & Body | 3 | 02-06-2013 07:38 PM |
How much fluid and pressure and sag? | gasser | Enduro Suspension | 0 | 04-16-2009 02:16 PM |
