Old 06-14-2019, 07:32 AM
Gez Gez is offline
Default 2018 ec300 no start
New to me bike 21hours on it, was a massive pain to start hot or cold when I got it so I did the choke plunger mod, put a #40 pilot jet into it, set the floats, AS 1.5 out, new plug. Also did all the wiring updates for the starter etc.
Now I can't start it at all, no spark when I use the kick starter, but decent enough when estart is pressed (won't start on estart when cold I guess).
I am new to 2 strokes but what could I be missing? I just want to ride the thing
Old 06-14-2019, 06:57 PM
Multi meter time!
Check the resistance for the stator, coil, and ht lead.
Worth while checking the flywheel nut as well. A couple have had issues which resulted in the woodruff key sheering and timing going out.
Old 06-14-2019, 07:45 PM
Gez Gez is offline
Thanks, I'll crack into that today
Old 06-15-2019, 02:37 AM
Gez Gez is offline
0.7ohms on the coil and 9.49(on 20k) on the plug lead.
Can't work out the stator wiring, the only workshop manual I can see has different coloured wires, so I'm abit stumped there.
Old 07-03-2019, 07:45 PM
Gez Gez is offline
Update:
Duh, duh, duh.
CDI wasn't plugged in correctly!
Old 07-03-2019, 10:28 PM
adriano.ro adriano.ro is offline
Plugged from you? Did you work on it or it was from factory in that way?
Old 07-06-2019, 05:24 AM
Gez Gez is offline
The bike had 20hours on it when I purchased it so no idea. I also disconnected the cdi whilst doing some checks, so it may have been my mistake!
Converting 2018 EC/GP to XC start switch Keg Enduro Electrical & Wiring 6 02-28-2021 04:25 PM
2018 ec300 Fieds83 Enduro Engine - 2 stroke 11 07-11-2018 09:40 AM
Reversing Start & Kill switches - 2018 Gibnut Enduro Electrical & Wiring 7 05-16-2018 08:03 AM
2018 YZ450 Electric Start Only-$9199.00 Moto7man All Other Bikes... 4 06-16-2017 05:53 AM
Three Year Head Start -- Parting out in 2018 AZRickD Parts 2 07-10-2015 09:49 AM
