Old 03-22-2011, 06:01 PM
Woodsknight Woodsknight is offline
Default 2011 ec 300
Ohlins Shock/Zoke forks.
Anybody had one in the rocks with the proper springs for their weight yet? What did you think of the stock valving?
I am 6'3" 210 expert level. Just ran the bike in soft terrian with sand bumps last weekend at Sandy Lane Enduro in New Jersey. I had just put in .46 fork springs and a 5.6 shock spring and the bike felt really well balanced. The suspension was excellent and I had zero complaints in braking bumps, acceleration bumps, whoops, log crossings, and roots. Just not sure how she will handle nasty rocks if I spin the clickers in the right directions.
Anyone set one of these bikes up for rocks with the stock valving yet?
2011 EC300e
Old 03-22-2011, 07:49 PM
widebear's Avatar
widebear widebear is offline
Banned
>.46 front 5.8 rear with stock valving. Nasty Nasty deflection on rocks! Same forks as on my Beta, for me i find them unridable in stock form.
Old 03-22-2011, 08:44 PM
Great :-) im so sick of miney for revalves
2011 EC300e
Old 04-04-2011, 11:43 PM
CACTUSREID CACTUSREID is offline
i'm not a A rider, but i consider myself a mid to strong B level. i've been reading the fork debate threads. I've only got about 3 rides on my 11 ec300 so far-my forks seem to be pretty good so far in stock form! i set the clickers as per recommendations found here and went riding. pretty stable in sandy whoop sections,decent on hard rocky two tracks at decent speeds,and they seem to be getting better as they break in. i wont back myself into a corner here,but so far i think i'm liking the suspenders on this bike.
Old 04-05-2011, 07:37 AM
thumperrider1 thumperrider1 is offline
how much do you weight with no gear and what springs? I pick my bike up next week. Can you share some clicker/sag settings?
2018 XC300
Old 04-05-2011, 10:44 AM
well!! i don't normally dilvulge my weight on the first date-but hey why not? I'm 195 lbs in my boxers in the am. geared up i'm approx 230 inc camelback and toolbelt,and gear. so far bike is just as i took it out of the crate. i haven't even had a chance to check the sag yet. clickers, i set mid range on everything as per a post i found on here. i know this sounds a little vague,but in my experience so far,i'm liking initial impressions with the suspension on this bike. i'm not an a level racer,but i can keep the big dogs in sight on most days.
Old 04-05-2011, 01:19 PM
Thanks. We'll see how it goes next week. I see lighter springs in my future.
2018 XC300
Old 04-05-2011, 03:54 PM
BrentMartell BrentMartell is offline
Why do you want lighter springs?
The bike should have .42 front and 5.2 rear. I am 170 without gear, 195 geared up, and stock fork springs were too light for me based on rider sag etc. I run .46's up front and stock in the rear for now. Rider sag seems to be in line with what the experts say it should be.
Stock fork settings is 11 on rebound, 10 on compression. 110 oil height and likely 7.5 wt oil.
Stock shock is 30 clicks on rebound, 16 on compression. They don't give sag settings just a pre-load. I personally have no clue how that works so I set mine to 30mm static and 110mm rider. 25-40 and 100-115 is likely just fine. I am not an expert on suspension tuning though.
Right now I run 22-25 clicks on rebound on the shock and from 8-15 (depending on where I ride) on the low speed compression. 2 turns on the high speed compression.
Try stock settings and see what happens. Go 5 clicks either way to see what if any affect you feel. Fine tune from there a couple of clicks at a time.
Old 04-05-2011, 05:09 PM
I'm 150 without gear and we ride nothing but tight stuff, so I was thinking 4.0's and a 5.0 rear.
Thanks for some clicker settings.
Sound like I need to stop bench racing this bike and wait and see how it goes after I pick it up next week.
2018 XC300
Old 04-06-2011, 10:19 AM
Yes. I would not do anything until you ride it.
If the suspension is not quite right you can put 5wt oil in the forks and lower the oil height. On the shock, you can reduce the preload and mess with the clickers. The ohlins shock has a wide range of adjusment.
2011 250 cc dublin General Discussions & Announcements 3 03-11-2011 01:17 PM
2011 xc 200 kdxtreme General Discussions & Announcements 4 02-22-2011 05:17 AM
2011 Mso - Us twowheels Enduro Product Reviews 9 12-02-2010 02:12 PM
2011 ec 250 brit General Discussions & Announcements 1 10-06-2010 06:57 PM
2011 Gas Gas' gasgasman Pictures & Videos 10 05-13-2010 02:45 PM
