Old 04-16-2021, 05:57 AM
'18 Novvy '18 Novvy is offline
Default Nissin Front Brake weak
Hi all,
2018 EC300 - Looking for tips on how to improve the stopping power of my front brake. I only bought at 50hrs and have done 15 of my own. I'm sure when I first rode the front brake was strong but now it definitely can't do a stoppie.
The brake lever can be firm but two fingers will get it to the bar. I assume when it's working right there's a firm limit to the lever travel?
Things I've tried:
  • Bleeding with stop/go technique
  • Rebuild front master cylinder
  • Bleed full line of fresh fluid with vacuum bleeder
  • Push pistons back a few times, to get any bubble into the main line
So far I haven't had a major change in brake strength. What am I missing?
Old 04-16-2021, 06:53 AM
SS109 SS109 is offline
Install a braided brake line. It's a common complaint on some Nissin systems. Also, change to a more aggressive brake pad compound.
Old 04-16-2021, 07:05 AM
Anders Anders is offline
I think the 2018 EC300 already has a braided line? As all other (at least relatively modern) Gasgas enduro bikes?
What type of brake pads and disk do you use (question to the OP)? Is it the OEM parts?
Old 04-16-2021, 08:50 AM
motoandrzey motoandrzey is offline
check if your brake disc is straight
Old 04-16-2021, 09:21 AM
Front tire slipping on rim?
Old 04-16-2021, 03:08 PM
Resurface the disc with wet and dry, then new pads decent type. Probably glazed but can just get unusable. If ever forks have leaked that would also kill pads.
replace pad pins if any grooves.
The mastercylinder can wear so bad that a rebuild won't work, but mine is an 07 so that's forgivable, at 50hr shouldn't be an issue.
Old 04-16-2021, 07:12 PM
One thing people always forget is the master cylinders seals need replacing every so often too. I change brake fluid annually as it is hygroscopic and most manufacturers give a four year replacement interval on all rubber parts of a brake system.
Complete Nissin Front Brake System mcnut Parts 12 11-19-2015 06:53 PM
Nissin Front Brake Pin Rick Enduro Chassis & Body 9 08-04-2014 08:16 PM
2002 EC300 front brake caliper (Nissin) Diedrix "Wanted to Buy" & "Want To Trade" 8 07-29-2014 12:48 PM
Weak front brake 04 ec300 jt633 Enduro Chassis & Body 11 12-22-2013 10:43 PM
Rebuild kit for '06 EC 300 Nissin front brake MC? brider Enduro Chassis & Body 0 03-10-2013 10:30 AM
