Old 05-16-2017, 09:52 AM
Avi3ator Avi3ator is offline
Default indicators not working EC 125 -10
Hi, my indicators are not working as they should on my new EC125 -10, they are connected correctly and everything its just that the indicator relay(?) doesnt get enough power from the bike, because when i connected it to a 12V battery it works. And the most volt i can get from my bike is like 3v, anyone know why?
Old 05-16-2017, 10:51 AM
Neil E. Neil E. is offline
Bad connection somewhere, maybe at the stator?
Old 05-16-2017, 02:18 PM
Uhm, how do i fix this? xD kinda noob :P
Old 05-16-2017, 05:36 PM
You have to start with the basics using a voltmeter. You need to unhook the stator lighting wires and check for AC voltage with the engine running. You should get more than 16VAC so the regulator has something to clip back to 12-14VAC. With the regulator added in and you should get fairly stable voltage.
At that point you go through looking for bad connections that would stop power from getting to the turn signal wiring. If you don't have the tools or the knowledge, take it to your dealer or find a buddy who can read the wiring diagram and test the circuits.
Lighting not working Wilksiee Enduro Electrical & Wiring 17 03-20-2012 12:34 PM
Indicators don't flash Klausen Enduro Electrical & Wiring 4 10-27-2010 07:47 AM
indicators not blinking wence Enduro Electrical & Wiring 0 11-15-2008 05:15 AM
Search not working stay_upright Suggestion Box 1 07-08-2008 08:17 PM
