Old 07-07-2011, 10:19 AM
Bailey28 Bailey28 is offline
Next time I will.... I need to start verifying these folks actually have parts in hand in stock in their store/warehouse....
'10 EC300 -- very happy
Old 07-07-2011, 03:00 PM
eric,
If you did the mod to the '00, and it had an old FMF Gnarly pipe, I suspect the pipe had a lot to do with it, and perhaps the older ignition. They put everything on the bottom. From what is reported the head mod is great on the new 300s, and I can say for sure on the 250s. The new bikes rev out more than the old XCs.
A few mm of slop should be adjusted out.
Old 07-08-2011, 07:58 AM
rgranger's Avatar
rgranger rgranger is offline
So it sounds like you lost some of that sewing machine smoothness of the motor? That is what I bought the GG for, the KTM 300 is just raw grunt!
Originally Posted by coopernicus View Post
Bailey,
Have you expermented with the different PV valve shims? I've been helping a friend solve an off idle deadness and he just checked his free play tonight on his 2010 300...The actuator is touching the stop but he says there is no real spring resistance for a few millimeters of movement possibly letting the PV open early. I have gone the route of the head mod on my 300 and, frankly, it seems to make the bike a bit "chuggy" like the KTM. He does not want that. Does anyone know if that lack of resistance would make the bottom soft just off of idle? Thanks for your help!
Eric
Rob Granger / Katy, TX EC300
Old 07-08-2011, 08:26 AM
Too bad widebear got banned, he ws working on raising the cyl for more mid/top port timing in conjunction with a squish/compression correction. Seems like this may end up like a big bad 250.
Old 07-08-2011, 03:50 PM
twowheels's Avatar
Send me a PM with what gaskets you need - I stock multiples for just this very reason.
Steven Beane #275
afterhourscycle.com
Old 07-10-2011, 02:11 AM
motogroove's Avatar
Will do next time.
I should be riding today and I'm not, because of gaskets.
That's just wrong.
Thanks to FLY Racing.
PV timing? Fred1956 Enduro Engine - 2 stroke 3 04-14-2011 11:40 AM
Timing a 450? iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-28-2010 10:17 AM
07 timing? wence Enduro Electrical & Wiring 15 10-28-2009 03:42 AM
Need HELP with timing gasser Enduro Engine - 2 stroke 2 03-23-2009 02:17 AM
For all who know Timing?? nwcycle General Discussions & Announcements 0 03-21-2009 11:25 AM
