Old 10-24-2018, 08:26 AM
eralha eralha is offline
Default Cilinder gasket kit 300 2018
Hi
Does any one know if a kit for a 2015 ec 300 would fit a ec 300 2018?
https://www.motocrosscenter.com/shop...25944101.html#
I'm starting to planing a piston change.
Regards.
Old 10-24-2018, 06:08 PM
Wuzofoz Wuzofoz is offline
I found this on eBay (item num 362081509427) so would guess yes a 15 base gasket will fit. I?m new to gasgas as well and just asked a similar question
Old 12-04-2018, 02:55 AM
Smith-80 Smith-80 is offline
Originally Posted by eralha View Post
Hi
Regards.
I have just received a gasket kit(genuine) from my dealer and have a metallic .5 gasket in it, I was looking for different gasket sizes so i could alter squish and port height. I would also be interested if the older gaskets fit so i can get a varied base gasket thickness.
Old 12-04-2018, 03:55 AM
Anders Anders is offline
I do not know, but I would be surprised if the older base gaskets doesn't fit the 18 and 19.
Edit: After checking the parts catalogs online, I see that both the 0.15mm and 0.30mm gaskets have the same part numbers for my 15 model and the 19 models. The 0.5mm gasket does not. I suppose that means there is a minor cahnge, but that older gaskets can be used?
2018 XC 250 Base Gasket Jacob 'Berg Enduro Engine - 2 stroke 4 08-22-2018 03:01 PM
Top end gasket kit poelinca Enduro Engine - 2 stroke 20 06-11-2016 11:06 PM
07 gasket kit into a 09? lonetree Enduro Engine - 2 stroke 3 07-10-2014 12:14 PM
Gasket Set. Marki Enduro Engine - 2 stroke 3 12-02-2011 06:15 PM
Base Gasket gtsnowcrack Enduro Engine - 2 stroke 6 09-09-2006 05:43 AM
