Old 08-21-2018, 02:03 PM
Default 2018 XC 250 Base Gasket
Anyone know stock base gasket thickness for the 2018 XC 250? I will find out in another 30 hours or so when I do a top end. I just do not want to pull the jug until it is time for that job...
Old 08-21-2018, 02:16 PM
Gottsell Gottsell is offline
Woundering the same.
And what piston height is recomended, cant find any info about that .
Old 08-22-2018, 01:34 AM
Eyeball it..
If its the metal coated one (black on each side) they are usually 0.5mm
Green is 0.3mm.
From memory..
My old 2010 had 1.3mm of gaskets packed between the cases and jugs stock!
Old 08-22-2018, 06:01 AM
All the 2018?s I?ve seen/heard of 250/300 have had 0.5mm like Jake said.
Old 08-22-2018, 03:01 PM
Thank you kindly gents!
wet base gasket thejackrabbit Enduro Engine - 2 stroke 6 02-09-2014 01:03 PM
Base Gasket re-use? motogroove Enduro Engine - 2 stroke 5 06-26-2011 07:56 PM
!!! Help with Base gasket thickness !!! timlh Enduro Engine - 2 stroke 1 05-14-2009 07:58 PM
Base gasket Ud_luz Enduro Engine - 2 stroke 21 05-09-2008 07:38 AM
Base Gasket gtsnowcrack Enduro Engine - 2 stroke 6 09-09-2006 05:43 AM
