Hand guard trouble.
I recently purchased a 2005 ec 250 all stock including the bars, came with enduro enginering hard guards, which worked great until I decided to move the levers into a stand up riding position (down), at that point nothing fit right due to interference with the pressure lines, tried offset mounts, no help. any good ideas?
Get one of these mounts if they fit:
http://www.ktmtwins.com/brp-ktm-upper-handlebar-mount-kit-for-handguards http://www.zeta-racing.com/handguard/mount/index.html I always had trouble with fitment of guards and controls alignment, but in the end i just got used to their up position.
'14 EC300 |
I have used the Cycra CRM mounts with good results. Never had trouble routing the wires, hoses and cables.
Cycra hand guard mounting options | thejackrabbit | Enduro Chassis & Body | 14 | 12-16-2013 01:53 PM |
Clutch Trouble | sammyj18 | Enduro Engine - 2 stroke | 10 | 07-24-2009 10:39 PM |
Hand guard issues | jhendr3702 | General Discussions & Announcements | 3 | 09-03-2008 04:10 PM |
Is Gas Gas in trouble in the U.S. | GregM | General Discussions & Announcements | 14 | 12-29-2006 08:55 AM |
